Question about RCA P52960 52" Rear Projection Television
I turn it on then off and it keeps going on and off
I have a 2002 rca 54" the past 3 days i turn it on and every few mins. it turns off and on again . i have checked all power to tv but everything looks good does anybody have any ideas? or maybe where i can find someone to fix it here north of toronto ?
  • andrew noble Jan 14, 2008
    i have had it fixed . it was the power regulator and cost about $150 installed and i havent had a problem since but thanks to all and your concerns
Im having the same problem with my set, same model and things. We have it where we turn it on, then it scrolls through channels and then shuts on and off. I would think it's the same thing as the solution mentioned. I know of a TV shop I can stop by and ask about this, what would the costs be associated with getting this fixed, so I know if he's telling me the truth. Thanks!
Posted on Jan 14, 2008
Hi, I don't have a solution for this problem but i have the SAME problem. Just wondering if you have figured this one out yet or not?! Noble, can you e-mail me and let me know? Or maybe reply to my post???
Posted on May 18, 2007
    Sergeant:
  • 308 Answers
There are two possibilitie that I can think of for this model set. There have been some instances where coolant from one or more of the projection tubes leak out and drip onto the PC board causing intermittent problems. If not that, then you could have a defective capacitor or intermittent solder connection causing the problem. Capicator C13105 - a 1uf/100v Cap Located Near U13101 Syscon IC has caused this symptom also. Hope you can find someone willing to come out in the cold to fix it for ya.
Posted on Mar 12, 2007
Rca flat panel tv turns itself off. LED light on pwer button blinks 3 times,but wont turn back on
With the model which is not indicated here Google that for 3 blinks to know what the error code means.
Dec 23, 2012 | RCA Televison & Video
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
Set wont turn on, Beeps.
Try Resolder all of the Big Diodes around power supply.
Feb 18, 2009 | RCA P52960 52" Rear Projection Television
RCA 24V414T KEEPS TURNING OFF tv works great,channels, color, remote control etc just turns on about 5 mins and then shut down, again 2 minutes off, and then turns on back again, sometimes work all the...
it could be a ghost but most likely a bad solder connection , crystal(controls the eprom)(menu chip) , or the eprom chip itself will need to be replaced
Dec 01, 2008 | Televison & Video
Rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Nov 08, 2008 | RCA 27V530T 27" TV
Rca 52 inch rear projection
This is a problem common with some RCA/GE TV's. The fix in the past was to install a capacitor between ground and pin 15 of the microprocessor which keeps a data signal riding on the video stream from muting the sound on most stations. By installing this capacitor, you would be disabling the closed caption feature so that feature would no longer work. An authorized RCA TV repair shop may be able to give you more information.
Apr 12, 2007 | RCA P52940 52" Rear Projection Television
RCA D52W20 Intermittent Power Issue
your problem is intermitent resolder the power supply the horizontal along with the area of the flyback you could be having some lose solder also resolder.if that does not work check around in the power suply some bad cap,power regulator and even the flyback again.a check should be made on the microchip.if you cannot do it your self take the set to a tech.good luck
Mar 29, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52960 52" Rear Projection Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
