Question about GE Spacemaker JVM1640SJ Microwave Oven
As a reply to the repeated microwave use and it doesnt work
How do i check the temperature on the magnetron for model jvm185owno2 spacemaker
    Sergeant:
    Champion:
  • 338 Answers
You have to take the shell of the microwave and if you have an electric meter then you would test for continuity throught the thermostat. or ohm it out. but take both wires off of it because you could get a false reading if the wires are still attached.
Posted on Dec 07, 2008
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
Microwave turns on, but never warms anything.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Feb 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs apparently normally, but food doesn't heat. all other functions appear normal.
Hope that helps.
Load test.
Feb 13, 2011 | GE Spacemaker JVM1740 Microwave Oven
I need to replace a 2002 GE Profile Spacemaker II Sensor microwave. It does not turn on at all, although the keypad (clock & timer) are working. I need one with the same dimensions as it is installed...
Hope that helps.
Load test.
Feb 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave isn't heating
Hope that helps.
Load test.
Jan 29, 2011 | GE Profile Spacemaker Over-the-Range...
Does not heat
Hope that helps.
Load test.
Jan 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave with vent fan
hi possible magnetron problem but also check highvoltage capacitor and diode . the process of ellumination is the only way to help u .first disconnect connegtor to magnetron and switch oven on if noise goes away eureka repeat with other components
Mar 18, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
