How do i get my computers isp number - Computers & Internet
  • IQUIT May 11, 2010
    Do you mean your system's IP address?
    If you do, the easiest way is as follows:
    Start, Run, CMD [enter]
    Ipconfig /all [enter]
    You IP address, MAC address, Default Gateway all are listed there.
  • 55 Answers
I'm not sure about your ISP number but on a PC from the start button find Run and type cmd. you should get a new window at the prompt type ipconfig/all and it will tell you your ip address, subnet, gateway, dchp and a few more interesting bits of information.
Goodluck
Rob
Posted on Dec 07, 2008
    Master:
  • 461 Answers
Run ipconfig from a command window (type cmd in the search for Vista or Start Run cmd in XP) then type ipconfig
Using WRTS4GS2 Cisco Router and could not access the internet. Remobed router and had instant access to the internet.
Contact your ISP. Some ISPs limit the number of computers that can simultaneously connect to your cable-modem. If you change computers, you have to tell your ISP.
Or, power-off your cable-modem, to "reset" it.
Connect the Cisco Router to the cable-modem.
Power-on your cable-modem.
Power-on your router.
Connect your computer to your router, and see if you get Internet access.
Dec 20, 2010 | Computers & Internet
No internet connection
f your modem isn't getting an answer from your ISP
  • 1 Make sure that the cable is correctly connected to both a phone line and your modem and that, if you're using an external modem, it's connected to the PC.
  • 2 Dial the access number for your Internet service provider (ISP) with a regular telephone and listen for a data tone. If you don't get one, then you have the wrong number or your ISP is down.
  • 3 If your modem is internal, skip this step. Unplug the power cord from your modem and shut down your computer. Plug the modem back in and restart your computer.
  • 4 If you have another modem cable that you can use to connect the computer to the modem, swap it with your current cable to rule out a bad cable.
  • If your connection is refused by your ISP
  • 1 Make sure your username and password are still correct. These are usually entered through a connection program that your ISP provided. You will probably have to retype your password, as you won't be able to read it on-screen.
  • 2 Locate the TCP/IP settings for your computer. In Windows, these are found in the Network and Dial-up Connection control panels. In Mac OS 9.2 and earlier, they're in the TCP/IP control panel. In Mac OS X, they're in the Network section of System Preferences.
  • 3 Check that the host name and domain name information are correctly entered in the TCP/IP settings. This information should have been supplied by your ISP.
  • If your connection is accepted but you can't load Web pages or send e-mail
  • 1 Call your ISP's support number to find out if you have been affected by a service outage.
  • 2 Unplug the power from your modem (whether it's telephone, DSL or cable) for at least 10 seconds, shut down your computer, plug the modem back in and restart your computer.
  • If your connection seems too slow
  • 1 Set your Windows computer to MS-DOS mode: Click on Start, Programs, MS-DOS Prompt.
  • 2 Type "ping" followed by an Internet domain name--for example, www.google.com or www.yahoo.com. Macintosh users with OS X can use Apple's Network Utility program to "ping." Earlier versions of Mac OS don't have it built in, but freeware programs are available on the Web.
  • 3 You should get a report saying how many milliseconds it took for your "ping" to reach the destination. A computer communicating with the Internet via a 56-KBps modem connection might typically have a 0.3-second (300-ms) or longer ping. Anything longer than 5 seconds (5,000 ms) indicates a problem with your connection that might be the fault of your ISP.
  • Read more: How to Troubleshoot an Internet Connection ' eHow.com http://www.ehow.com/how_113839_troubleshoot-internet-connection.html#ixzz15EpuN33C
    Nov 14, 2010 | Sylvania G-Netbook
    Have no setup cd with my belkin F5D7632UK4A how do I install it?
    You dont need a setup CD as this is a router. you should have the manual which will explain in detail the process of installation. If you dont have the Manual as well, then provide the below details and i can help you fruther on this
    Name of the ISP:
    VPI / VCI value (to be collected from ISP):
    Total number of Wired computer/s:
    Total number of Wireless Computer/s:
    Operatins System used on computers:
    Feb 15, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
    I have a linskys EQ-660R ADSL Router and i am trying to make my NAT type open. I've got UPnp and checked all boxes...nothing happened. here i will give u my options on the advanced menu. (Password) (LAN)...
    you need to set
    wan type to PPPOE for ADSL
    ADSL has one IP address coming out of your building to the ISP
    How does it connect many internal computers to just one outgoing IP address you may wonder. It uses different port numbers for each computer on the same ip address via a PPPoe connection .
    http://searchnetworking.techtarget.com/definition/PPPoE
    if still stuck call your isp for help
    you will most likely need dynamic IP for the isp ip and DNS /
    Jun 17, 2017 | Zyxel P660HW-D1 Router
    Whenever iam making a call ihear a sound.the service to this number is currntly unavailable
    When you talk about making a call, is it to connect the computer to the internet, using a dialup connection? I would call my internet provider, and confirm the telephone number, first. Then, if there are still problems, get their tech support to walk/talk you through your computer settings. I've done that so many times with various ISPs on so many different computers, after having similar problems.
    Alternatively, If you have DSL service, do you have a FILTER connected between each outlet and a phone? Your ISP usually provides the filter, and it removes the digital signal used by the computer, so you can make normal voice calls.
    Nov 22, 2009 | IBM PC300GL Celeron 6275, 6285 (61H1061)...
    How do i get my dns numbers from my isp provider,and what is a isp provider.
    Best bet is to open up your browser and type in www.whatismyip.com
    this will give you your ip address from your isp provider (Internet Service Provider)
    If You need some DNS numbers (Domain Name Server), I use open DNS. they are pretty good at keeping out dodgy or rogue sites. Web sites have actual numbers for their address, not names. When you type in www.anynamehere.com, the computer goes to the DNS server to look up the name and get the number (IP address) just like looking up a phone book.
    If you choose to use Open DNS as the look up server. use these numbers in your settings.
    DNS1 208.67.222.222
    DNS2 208.67.220.220
    If you need to put in a gateway (like a front door to go out to the net) you will need to go into your router or modem settings to find this number, Or just call your ISP to get the information. You will need your email username & password before you ring
    Good Luck
    Nov 17, 2009 | Microsoft Wireless Network Adapter Xbox...
    Dns numbers
    Maybe you have a bad Xbox 360 Wireless Modem.
    Feb 16, 2008 | Microsoft Xbox 360 Console
    Internet Connection Stops When Router Added to my Network
    Some ISPs validate your access by checking a number which is in the computer that was used when the ISP did the installation. see: http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102076
    Feb 19, 2006 | NetGear DG814 DSL Modem Internet Gateway...
    No Internet With New Router, Computer, or Adapter
    This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
    Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
    Computers & Internet Logo
    David Payne
    David Payne
