Question about Elna 2007 Mechanical Sewing Machine
Elna SU My elna will not run. It was running fine then all of a sudden when I pressed down on the control it would no longer run. No noise, nothing. The light is still on.
Check the brushes in the motor. My old Elna super did the same thing. We replaced the brushes and it has been working like a charm ever since. It's 40 years old and still going strong.
Posted on Dec 14, 2008
I need an Air foot control # 436310-20 for my Elna Stella TSP air electronic. How and where I can get this part?
I'd suggest www.sewingpartsonline.com if you are in USA.
https://www.sewingpartsonline.com/air-foot-control-elna-436410-20.aspx
Or you could try the Elna Guru, White Sewing Center www.whitesewingcenter.com, he's the specialist supplier for all things Swiss Elna.
The air control foot is the same for all the Elna Air Electronics, whether Stella, SU, TSP, TX etc.
Mar 20, 2017 | Elna Sewing Machines
I am unable to wind the thread on the bobbin, it's loose and seems to knots up. I have and Elna SU.
Hi. Try this site to look at a free online manual.
https://www.manualslib.com/products/Elna-Su-2614738.html
I hope this helps!
Feb 12, 2017 | Elna Sewing Machines
I have an Elna Carina SU model no. 65. The spool pins suddenly stopped rotating when I was refilling the spool, although I could hear a motor running quietly when I pressed the foot control.
I'm just wondering if the machine has been checked, cleaned and oiled by a technician recently. These old mechanical machines usually need regular oiling to keep going. Not sure if that is the problem, but sometimes mechanical machines have parts that lock up over time.
Best Thrifting Ever
Jan 24, 2017 | Elna Sewing Machines
Why do the automatic stitches and cams on an elna su not work?
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jun 08, 2014 | Elna Sewing Machines
Zigzag feature is not working
Jan 09, 2014 | Elna Sewing Machines
My Elna su from 1975 runs now only at top speed even if you dont push the footcontrol Has always been very reliable and I dont whant to get rid of it.
If your foot control is not an air control but electric then the chances are the suppressor has blown in the control, open the control and take out the small suppressor, you can then use the machine you don't need that part
Sep 21, 2013 | Elna Sewing Machines
Elna SU 62 won't stop running. I wired a universal foot control to my original power cord but the machine runs unless it is unplugged. Others have asked the same question but I can't find a detailed...
go to yahoo.com and join the Elna Heirloom group there. Several of the members are very knowledgeable and I've read fixes on this issue there.
Mar 21, 2011 | Elna Sewing Machines
Elna supermatic...the light comes on ,,but nothing else works
Turn the machine on, press the foot control down and turn the handwheel backwards. If it sputters, the motor carbon brushes are worn to the springs and need replacing.
Next, while pressing on the foot control, try wiggling the wires around where it enters to machine and where it enters the foot control. There may be a short in the cord. If the short is at the machine, you need a new cord. If it is at the foot control, the cord can be pulled into the foot control, the shorted part cut off and the connection reattached.
If it still doesn't work, try removing the cord from the machine and placing an alligator clip test lead to two of the inlet prongs on plugging it into power. Which two prongs you ask? Try several combinations, (one will light up the lamp) CAREFUL: THE MACHINE MAY SUDDENLY TAKE OFF AT FULL SPEED, SO REMOVE THE BOBBIN, THE THREAD AND NEEDLE FIRST. if it runs, it is your foot control. If it doesn't run, it's likely the motor brushes or motor.
Dec 11, 2009 | Elna Sewing Machines
Elna su motor won't turn off
There wasn't anything like a suppressor any other ideas?
Jan 24, 2008 | Elna 2007 Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
444 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
