Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer is not getting cool
How can I put freon in it myself
  • Shane Hays May 11, 2010
    How do you know you need freon?
    Scholar:
  • 62 Answers
Most likely if you have to ask this question it is better you do not try it as it requires that you add a service valve and need 134a service gauges and know how to read the gauges and know how to handle freon as it requires a license to safely handle this chemical.
you should look for other causes for no cooling, as is, is the compressor running? Are the cooling fans running or do you have a defrost problem that is evident by frost showing on the back side of the freezer?
Posted on Dec 07, 2008
Stuff in freezer is thawing. Outside edge of freezer and center divider between refrigerator and freezer getting very hot to the touch. This comes and goes.
this refrigerator had slow leak. last time 6 month ago, another tech from our company was there and charged refrigerator with freon and leak dye. now i found leak dye with special light in the drain pan, spayed with soap - bubbles come out. Replaced that drain high side line. Hope that helps.
Feb 09, 2015 | Refrigerators
Neither freezer or refrigerator will not stay frozen or cold.
had similar problem few yrs back it may be gas or if its a frost free one check for and damage on inside walls of freezer as this reduces ability to stay at right temp
Sep 26, 2012 | Refrigerators
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
The freezer is not freezing. Is cold only.
The problem which you mentioned is related to faulty/ weak compressor.--------- I will explain with more detail.------
Jun 28, 2011 | Refrigerators
Freezer no longer stays cold enough to freeze food. Ice box side ok.
its shot that or you need to add freon to the compressor it will have to be a certified epa person like myself it also will need a shreader valve put on so you have a way to get the freon into yhe compressor
Feb 24, 2010 | GE Refrigerators
I have a side be side, refrigerator plus freezer and ice maker...
First check your freezer temp. if your freezer temp is good then your problem is that your not getting enough air from the freezer. This could be because of the damper door or what is controling the damper door. Put all your freezer and freshfood settings in the middle for 24hrs and check temps. and make sure the freezer fan is working.
If freezer temp is not good you could have a freon leak or a bad thermostat or defrost problem.
Jan 08, 2010 | Refrigerators
Warm
If you need freon you can't do it yourself
Could be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | GE Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
