Question about Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio
Powering the Yaesu FT-11R
Normal 0 I have downloaded the schematic for the FT-11R. It shows a "Contact Unit" as the interface between the rest of the radio and the supplied battery which is 4.8 VDC. The radio is supposed to be able to operate up to 9.6 VDC.
The problem is that the supplied battery pack and the radio have 4 pins going from the radio to the battery pack. Clearly, one pin is + 4.8 VDC, one is ground. The problem is what is the function of the other two pins?
One is labeled "Battery Select" and the other "Adjust" on the schematic, but what do these really do?
Has anyone simply hooked up the + and minus leads to a bench power supply without causing any harm?
de Rich, W6APZ
P.S. I can forward the schematic of this interface unit as a .jpg file attached to an email if this will help respond to the above question.
    Master:
  • 623 Answers
The battery select determines whether you're using a NiCd or Alkaline battery, I believe the "adjust" is used to put the radio into service mode. If there's not an "auxiliary power input" you can hook up the bench supply to, check the battery output for the voltages and polarities, and hook up your supply accordingly.
Posted on Oct 30, 2013
4 Suggested Answers
SOURCE: Yaesu FT 11R
figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Posted on Mar 17, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Yaesu FT-51R purchased in mid-year 1995.
Yes, it is possible to use the FNB38 NiMH batteries or any other battery as long as it is the same size and the same volt. Once the battery can fit into the radio and charger and has the same volt, then it is definitely going to work.
I hope the above is clear and understandable, if not, please let me know.
Good luck.
Posted on Apr 25, 2011
External mic for ft 50 yaesu purchase
Yaesu offers the MH-34B4B Speaker Mic or the MH-37A4B Earphone Mic for the FT50 HT.
Speaker Mic (Heavy / Standard Duty)
Earphone Mic (Light Duty)
Any ham radio store should be able to obtain these - if they are still in production / stock by Yaesu. Ham Radio Outlet aka "HRO" has stores nationwide and can ship direct.
I hope this helps!
Jan 26, 2012 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
I want a manual for a yaesu vx-5
You can probably find it on www.mods.dk - you may pay a small fee, but they have manuals for most ham radios.
Sep 27, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-11R amateur radio squelch problem
It sounds like perhaps you have CTCSS turned on so it's blocking received signals that aren't using sub-audible tones. Make sure the "TSQ" indicator is not showing. Most Yaesu radios have the SQU or "T.SQ" option easily found in their menu structure..
Nov 12, 2009 | Vertex FNB-38, YAESU,FT-11R,FT-41R,FT-51R,...
FT-11r no longer powers up with a known fully charged battery ? The battery was left in the unit a couple of months with a discharged battery. Could this have damaged the unit ?
It's unlikely leaving the battery pack attached ruined the radio, unless it leaked and corroded the contacts. Be sure they're clean and bright. Double check to be sure the battery pack really is charged to rated voltage.
Oct 09, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Service manual/parts list for yaesu ft41r or ft11r
You should be able to get the keypad from Yaesu parts: \
(714)827-7600
You may be able to download the manuals at: www.mods.dk
Sep 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
I have an FT-51R and when I try to turn it on with a full battery nothing happens
Carefully clean the contacts on the battery and the radio. The contact area is so small that the slightest amount of oxidation or corrosion will prevent the radio from working.
Dec 24, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT 11R
Sep 28, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
Jul 14, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio Logo
270 people viewed this question
Top Vertex Radio Communications Experts
Steve
scott265
Level 1 Expert
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
