Question about JVC HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System
Protect mode for jvc hx-d7
I turn it on then it says protect and shuts off... how do i get rid of this problem
  • 2 more comments
  • cassievking Dec 07, 2008
    when i turns on my stero it only stay on for like 2 seconds and then it flashes protect and shuts down right away
  • Anonymous Jan 17, 2009
    display shows protect then shuts down
  • zubo1 Mar 23, 2009
    i turn it on then after a little while it flahes protect and it shuts off how do i take it off
  • sandrap Mar 31, 2009
    I have a JVC model: ca-hxd7. The only things conected are the speakers, we disconected them and I get the same messages.
    "Power On",
    "Status",
    "Protect", then
    "Power Off"
    And the stereo turns off. I lost the control to it and cant find the manual. I have no idea of how to fix this problem. Please someone help me.
SOURCE: PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
I had the same problem with a jvc stereo set, it turned out the two cables of a speaker were touching each other.
Posted on Nov 30, 2007
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Posted on Nov 23, 2008
  • 53 Answers
SOURCE: my jvc hx-d7 radio is turned on in 2 seconds it
You can't. The main amplifier module will probably have a channel blown. The unit is detecting this and tripping into protect mode to stop further damage occurring. Needs to go to a repair place. sorry. ps If you get sound briefly before it trips off then it may just be a speaker wire shorting out! worth checking
Posted on Nov 07, 2009
CW Oly
  • 240 Answers
SOURCE: I turn on my JVC HX-D7 and will stay on
It sounds like you have a short. Check that your speaker wires are not crossed at any point. If no look into the connections and see if some wire has broken off into one and caused a short.
Posted on Jan 15, 2010
dunnbiker
  • 8546 Answers
SOURCE: MY JVC HX D7 IS ON PROTECT MODE
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 07, 2011
I turn on my JVC HX-D7 and will stay on momentarily. Then it goes into 'Protect' mode and will shut off.
Jan 14, 2010 | JVC HX-D7 Shelf System
My jvc hx-d7 radio is turned on in 2 seconds it shuts down to protect mode how do i take protect off ?
Nov 07, 2009 | JVC HX-D7 DVD Compact Stereo Audio / Video...
PROTECT MODe
reed the users manual...does it say anything about the protect mode ?
Aug 13, 2009 | JVC HX-D7 Shelf System
Sep 27, 2008 | JVC HX-C6 Shelf System
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Feb 08, 2008 | JVC HX-D7 Shelf System
Protect mode
Hi ,
Jango
Jan 26, 2008 | JVC HX-D7 Shelf System
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
495 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
