Question about Samsung YH-925 MP3 Player
Initial fail error
I have a samsung digital audio player YH-925. When i turn it on it won't work, i get a message that says.... Initial Fail The device cannot initialize HDD. Please connect to adaptor and try again and will be turned off. Any ideas why this happened?
  • 1 more comment
  • amolinro Dec 08, 2007
    that says....
    Initial Fail
  • Jovhenel Feb 29, 2008
    I've followed already the solution #1 but it is still not working? what should I do? I do want to fix it as soon as possible, please help me...
  • Anonymous Dec 06, 2008
    i have same problem
    Problem Solver:
  • 10 Answers
The HDD is disconnected from the player. When you open up the player just carefully push the circut board thing on the gold foil behind the hdd in untill it clicks.
Posted on Jan 01, 2008
  • 24 Answers
Comments: Apr 04, 2008- i just changed the battery in mine and got the message saying "Initial Fail {device cannot initialize hdd, please connect to adaptor and try fix"
i found out i'd dislodged the hdd connector on the main board so i reconnected it and all works fine again.....
if the music studio software above did not work then undo the 4 screws on the back of your player and take off the back
than get a stanley knife or another thin tool and lever the hdd out by inserting the knife in only a fraction "because circuit board 10mm back" between the main mp3 player housing and the rubber on the hdd and prise it out....then check the hdd is connected properly to board by pressing lightly on hdd connector....should click if its loose, the click is it inserted correctly.....if not working after checked connector i'd personally remove hdd cable from board then reconnect just in case of a dirty or faulty connection....
hope you get your problem sorted...post here if you do....jed
Posted on Sep 03, 2009
I followed the above directions and my player worked right away. Unscrew the 4 screws on the back and pull off the plate. I pulled on the 2 loose rubber tabs though which pulled out another panel. I then just pushed it back together and then turned on the player. It worked right away.
Posted on Jan 06, 2008
SOLUTION: HDD out, see how it clicks, pressing it in, works except for there is nothing to keep pressing it in. Took a book of matches, cut 1/2 off the end of it (just the cardboard) and stuck it between the gold connector and battery, so that when lid is back on, it will press on it. For mine, this wasn't enough so i took another match, ripped of the head, and laid it between the actual cover and ontop of the rubber, diagonally between the cover and the rubber. Had to put the screw in really hard, cause you're basically squishing the cardboard, but there is constant pressure on it now, and no problems. Good Fix .. THANKS!!!
Posted on Jun 07, 2010
  • racingfan_20 Jun 07, 2010
    Ok, sorry here is how it SHOULD read:
    Recapping what was said before, with my own 2 cents worth.
    From Jed1969:
    " ...undo the 4 screws on the back of your player and take off the back then
    out by inserting the knife in only a fraction" ..."between the main mp3 player housing and the rubber on the hdd and pry it out" NOTE: PRY IT OUT WITH THE RUBBER INTACT, DON'T TRY TO REMOVE RUBBER FROM HDD ..."then check the hdd
    correctly" ..."i'd personally
    reconnect just in case of a dirty or faulty connection...."
    This was indeed the problem for me, now
    you could also take some of that sticky rubbery foam **** like in cell phones and electronic devices, and place it between the gold sheet and the hdd, but shoving something between the two things seemed to be asking for mishap, so the match stick thing, (or anything of comparable dimensions, a folded up piece of paper, or anything.
    Thanks for the good advise, as usual, long time reader, this place has many good answers, and the answer to my problem this time was no exception.
    Thanks also for all of you who tirelessly post and repost to give feedback and help to us. If it were not for your dedication to help, live would not be nearly as easy.
I have the same problem...I did replaced the battery and I have the same message: INITIAL FAIL.......the device can't initiate.....HDD.....I tried all the 3 solutions buy I didn't get any progress....any more ideas?
Posted on Jul 14, 2009
I hit the reset button at the rear. It worked after 2 hits in the reset. Now I wonder if it will last....
Posted on Jan 08, 2008
Power cord
You can find a replacement AC adapter for this model from a major Samsung parts distributor at the following link:
Samsung YH-925 Replacement Part AC Adapter Cord
Jan 30, 2009 | Samsung YH-925 MP3 Player
Samsung YH-J70
I had the same problem - the hard drive had failed, which is a common fault. I bought a new one on eBay - a Toshiba MK3006GAL 30GB - which worked fine.
BUT... the drive came completely unformatted and I had to format it on a laptop first as I could not get it to format in the YH-J70. If the drive is FAT32 format, however, you should be OK to just put it in the YH-J70 and format it with Samsung Media Studio.
Sep 19, 2008 | Samsung YH-925 MP3 Player
The device cannot initialize HDD?
Remove the back panel of the player you will probably find that it will work fine. I did this to my daughters unit and found that the panel was pushed in and depressing the reset button all the time. I rescued it out of the garbage when she bought an i-pod, now I have this unit for myself and it works great.
Jul 26, 2008 | Samsung YH-925 MP3 Player
Samsung digital audio player yh-925
i hav a problem in my samsung yh-925 it's capacity of hard disk is 20 gb when i open my audio player then the error "boot loader ver 1.10" soo please send me this solution fast i m waitng for your reply.
Dec 03, 2007 | Samsung Yepp YP-T7JX MP3 Player
Yh925
I know your problem. Your HDD is not clipped in. Press that little square circut thing in untill you hear a click.
Oct 13, 2007 | Samsung YH-925 MP3 Player
Samsung YH 925
Hi, run the recovery utility that you install from the CD. Reinstall firmware. C
Aug 07, 2007 | Samsung YH-925GS MP3 Player
Problem with YH-925
It appears you need to use the rollback program, or the recovery program. But it also sounds like your usb cord is either broken or not plug in tightly. Press the usb adapter in untill you hear a click then plug it into the pc.
Feb 10, 2007 | Samsung YH-925 MP3 Player
Samsung YH-925 MP3 Player Logo
1,149 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
