Behringer Eurodesk SL2442FX-PRO 24-channel Mixer with Digital Effects is the product I own. Can I get one bus bar to to be the only "send" that would go to the tape/out designations?
  • Anonymous Feb 27, 2009
    can i get the cd line out desiganated to one certain channel other than the main, so that the monitor will not blow? rather than use the auxilary send for the only monitor mix. i would rather use the independent monitors for the main outs.
marsrover
  • 682 Answers
SOURCE: the main bus on my
please make all your fader down-all your rotary control at middle(12 oclock position)------all your pressed pushbuttons in up position--disconnect all inputs cables----use good new cables for outputs---bring a good mic and connect it to any channel and raise its fader up and main mix faders up and check if the problem solved check your cables and your pressed button if not better to contact a good service center.
Posted on Aug 17, 2008
SOURCE: Behringer eurodesk mx9000 Power supply
After a little research I discovered that Behringer has had problems in the past with there power supplys so I replaced the faulty one and so far the problem has been solved. Our local power company has been sending to much power to our church building and that is what caused to old power supply to burn out. We are still trying to get them to take care of their issues.
Posted on Sep 20, 2008
  • 5603 Answers
SOURCE: Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Posted on Jul 28, 2009
  • 1138 Answers
SOURCE: i need to get step by step direction to set up a behringer cx 340
You will need to carefully read all your manuals and proceed step by step Here is the first one to look at:http://www.behringer.com/EN/Products/CX3400.aspx This crossover goes between the output of your board and the input of whatever power amps you are using. It has sections describing each setup and by what you have said, if you have enough amps you would probably need to run stereo 3 way which is described on pages 9,10 and 11. This would allow you to run a mono sub out setup. The grey areas are the connections and controls you use. Make absolutely sure your cables match the ones in the diagrams and read and heed carefully all the warnings. As far as your E.Q. and your Compressor they are separate topics as they are signal processors and are hooked up in the signal chain of your mixing board. They condition the input signals. Your crossover belongs in the output stage which as mentioned before is from the output of your board to the input of the crossover then from the outputs of your crossover to the inputs of your amplifiers and then on to your speaker systems. Try to find a friendly person on your end who does sound on a regular basis and has experience setting up and troubleshooting connection problems who wouldn't mind trading some advice for whatever help you could offer them. You have some good gear there and although there are people who will give Behringer gear a bad rap, I have never experienced any problems with mine. You absolutely have to understand all your gear inside out and not try to make it do something it is not designed to do. You also have to make sure you understand the differences between balanced and unbalanced cable connections and only use good quality cables designed for each application. If you're good at soldering and understand all the theory and want to do the work you can probably buy in bulk and customize everything to your own purpose. Enjoy your new equipment.
Posted on Aug 28, 2009
Testimonial: "good advice, will used them "
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
I cannot hook my Behringer mixer to the Pioneer EFX 500 it's not working
I presume you are using the send and return inputs on the EFX500.
Make sure the effect selector, CH Selector and EF On/off are set right. then use these in the insert chain of the mixer for the channel/bus/sub you want to use the effects on. Remember on the mixer it will be tip send and ring return. It would be useful if you said which behringer mixer (they make an awful lot of them from complex digital to simple DJ) and what you are trying to do with it.
It is clearly explained in the Pioneer manual under basic connections. If you are a DJ you may not be familiar with the Insert concept so get yourself down to a professional sound/PA outlet or Radioshack / Maplin and ask for a pair of insert leads.
May 23, 2016 | Behringer Music
I imported a behringer SX3242FX today and it was working fine for about an hour suddenly I felt the digital effect that I selected( Delay ) has lost from the microphones and voices became dry.. Then I...
Is the number on the effects display still flashing? Can you select effects or is that section dead now? I've had occasions with my Behringer mixers where a bad ground or otherwise improper power supply seems to cause issues with the effects section but the board seems otherwise functional. It has definitely had me scratching my head a few times and is worth investigating.
Aug 17, 2012 | Behringer Sx3242fx Eurodesk 32-channel...
How do i wire up an effects unit for the eurorack pro RX1602? It only has a mono/FX output socket.
In your user manual on page 7 is figure 3.2 wire your effects unit like the Virtualizer they show... driven by that mono/fx send and the the effects return returns coming back into unused channels...
Sep 13, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Line/Phono switch? Cant find them
Look on the switch for a brand name... often they use a lot of ALPS products. I normally search DigiKey.com and Mouser.com, and Allied electronics and Newark.com.
Behringer online is of little help. I have called them and got parts directely. They don't stock a lot and sometimes it takes a little while to get the product.
May 06, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have an operational problem.
Here is Behringers website:http://www.behringer.com/EN/Support/ If you look at whatever model you want under products, the download link for the manual is usually on that page. For any other manufacturer, try typing the manufacture,model number and support or manual into Google or your search engine.
May 05, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
My effects on the behringer djx 700 dj mixer stop working how
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
152 people viewed this question
 Grubhead
Grubhead
