Question about Mitsubishi WS-55805 55" Rear Projection Television
Tv works, DVD, Xbox or anything requiring a different input
Our Mitusbishi Ws 55805 works fine for regular television watching. If you want to watch a dvd or play xbox, then the pictures are either in green or do not display at all. Is there an easy fix?
I had the same problem- i forgot wht caused it but it had something to do with the type of inputs i was using. try using the normal RCA inputs or S-video input for the DVD or Xbox
Posted on Nov 06, 2007
SOURCE:
All other input works fine e.g. dvd, TV went pink screen.
If other inputs show no problems and you are not using a cable box or satellite receiver, etc. just off air antenna, something on the main board is failing. please double check other inputs again.
Feb 17, 2014 | LG 32LC7D Television
ONLY HD picture does not fit on WS-55805
To be kind you are wasting your time, This is a 1st generation HD set not designed for the modern equipment you are using---You cannot turn a Model A Ford into a Roll Royce.
I has only one HD input designed for a set top HD box providing it a 1080 I signal.
Dec 04, 2012 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi hd 1080
What about the cable input? Does it work?
Sep 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
I have just hooked up a dvd player to the TV, and we watched it one time just fine. Now when we try to watch a DVD we just get an audio sound for about 2 seconds, and then nothing at all. There is no...
have you attempted a different video source into the TV (Gaming system, another DVD player, Reciever)?
The issue may be that the cables you are using may be old, and are severely damaged. inside of those cables is a standard RG-59 Coaxial Line that is extremely flimsie.
try and use separate cables or a separate input.
If the input change works, is most likely the switchboard on your TV (Hardware) and will need to be serviced. Another option to use is a Video switch ($35USD), and not pay $300+ for system repairs.
Aug 27, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Never hooked up the HD
Have you tried selecting a different input( do you have the remote?), if so have you set your input to accept HD input ( you access this thru your 'Menu" button on your remote). I run my HD input from my game console (X-Box 360) and have to select HDTV input channel (there are 2 of them along with 2 cable inputs), and have not had a problem with this at all. good luck.
Mar 18, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Tv looks fine when playing movies or Tv but looks all teac blue when using xbox360
Depending upon the signal, perhaps the convergence is off all the time, just not seen. If you can solder, try resoldering the convergence IC pins. Let me know if there is any change.
Thanks,
Dan
Sep 24, 2008 | Sony KP-51HW40 51" Rear Projection...
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
Mitsubishi WS-55311, 4 yrs old, flashing screen on all inputs
First thing to try is to press the reset button on the front of the TV. This forces a system reset.
Feb 03, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
