Question about Microwave Ovens
After using the microwave repeatidly it refuses to heat even after 30min cool down microwave inside is warm
    Sergeant:
    Champion:
  • 338 Answers
Check thermostat on the magnetron
Posted on Dec 07, 2008
Microwave runs intermittently...heating seems to shut off when warmed up and runs again when cooled down...is thermostat defective or does it need to be adjusted?
Some ovens have a thermal protector on the magnetron. It opens if the magnetron gets too warm. Or, sometimes they will open at too low of a temperature. Another possibility is that air flow to the magnetron for cooling is bein restricted, or the cooling fan is defective.
Jan 09, 2017 | Microwave Ovens
Microwave runs good for short heatups. But long or repeated heatups the microwave gets warm and shuts down. Will restart after cool off.
Magnetron thermostat is sensing over heat condition, it the fan running to cool it while running
Nov 21, 2015 | In Microwave Ovens
My microwave used to continue making sounds even when item was taken out and cooking time completed. I thought this was part of the mictowave cooling down (sim to fan oven). However, this noise has now...
All microwaves do have a "transmitter" tube called a magnetron. It has to put electrical power into microwaves. To do so it gets warm or even hot. As soon as the transmitter is to hot, it must be cooled down. Most of the time it can be cooled without a fan. But as long as the thermostat indicates it is to hot, the system will cool. Even when you switched the system off. Don't unplug the microwave when it is still hot. It could damage the magnetron.
Jan 15, 2015 | Microwave Ovens
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Ge pvm2070smss shuts down
It may be a noisy magnetron if the failure occurs in a second or two of hitting "Start" to begin cooking.
See this FixYa solution. even though your model number is different.
Otherwise, if the internal cooling fan is not running when you are cooking, it will shut down after 30-60 seconds or so and stay off until it cools back down.
Also see http://www.microwavedisplay.com/jvm2070.htm
Feb 24, 2013 | GE PVM2070SMSS Microwave Oven
WMH 1162X VS -1 (watts unknown) Builder purchased
If the oven is set up to vent outside, then the metal mesh grease filters are used, and they should be cleaned in warm soapy water whenever they look greasy or dirty.
If the oven is set up to recirculate, then the charcoal filter is used, and it must be replaced (not cleaned) every 6-12 months, depending on use.
This model does not have a separate cooling fan like most other models. It replies on the vent fan for magnetron cooling, so if the filter(s) gets too dirty, it can reduce the cooling air flow, which can allow the magnetron to overheat and be destroyed.
I would need to know a little more to help narrow down the "no heat" problem.
If the cooling fan, turntable, and inside light all come on when you press "Start" to cook, then I would ask if you here a "thump" when you press "Start."
If so, then the high voltage section is getting energized. If not, then it may be the cook relay on the control board, which I can affordably repair.
The support page for your oven is here, and it has manuals and part lists you can download.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | Whirlpool WMH1162XV Microwave Oven
Microwave felt very warm on top. after cooling
That's often a sign of impending failure of the magnetron or a failed or failing internal cooling fan.
One should never leave a microwave unattended while cooking, and it's even more critical any time there is a problem or potential problem.
With the model number, we can offer more specific advice or an estimate.
But since FixYa does not notify us of follow-ups, you will need to post a new help request.
May 31, 2010 | Whirlpool GH8155XM Microwave Oven
Overheating bottom Kenmore 66560652000
I would suspect that when the microwave oven was on the table the vent or air openings were restricted by the table. Without free flowing air the control and other components could build up heat. It is doubtful that you built up enough heat to damage anything as this unit has more than one over temperature safety devices built into it.
That being said, the excess heat could weaken something internally especially on the control that would cause it to fail sooner than later in life.
My advice would be to leave it unplugged until it is mounted back on the wall per the instructions and use it then as normal. If it fails in the next year or so replace it at that time.
May 03, 2010 | Kenmore Microwave Ovens
Microwave problem
Could be that magnetron is not receiving adequate cooling thus causing thermal protector to open. This is mounted on the magnetron.
Jul 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
