Question about Ricoh Aficio SP C410DN Laser Printer
Paper pick-up for by-pass tray won't work
I have a Ricoh c410dn.
When I load paper in the by-pass tray, the printer normally sucks in the paper half way and then pauses awhile before it sucks it in the rest of the way and prints it.
Now, when it should **** it in half way, it stops and tells me that there is a paper jam and I must open the front and remove the paper; but it never sucked it in. There is no paper jam.
It works fine for the bottom tray (called Tray 1).
Thanks for any help you can give.
Henry
    Genius:
  • 1,199 Answers
OPEN BACK AND LOOK FOR A SMALL PIECE OF PAPER FROM PRINT JOBS PAST THAT MAY HAVE JAMMED ...FOLLOW THE PAPER PRINT TRAIL, CHANCES ARE YOU WILL FIND SOMTHING BLOCKING THE PATHWAY!
Posted on Dec 07, 2008
The Ricoh Alicio SP C410dn says to open the A tabs and remove the paper jam. There is no paper jammed into the machine. The issue only arises when printing from the manual feeder and not from the paper...
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
Feb 25, 2011 | Ricoh Envelope Feeder Type 610 Feeder Tray...
Not picking up paper from tray 1
the printer need the pickup and registration clutches cleaned or replaced beyond the scope of the average user call for a ricoh csr to come and replace the clutches they are inexpensive and it will save a lot of time
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Ricoh Aficio C410 bypass tray not picking up and reporting jam
This is happening to me also. The rollers sound like they're turning, but the paper doesn't advance. I then go into th emachine and spin the roller cam a bit and it seems to clear the problem. Any idea what's happening?
Jun 09, 2009 | Ricoh Aficio SP C410DN Laser Printer
AFICIO SP C410DN BRAND NEW OUT OF BOX. PAPER JAMMING COMING OUT OF PAPER TRAY AND BYPASS.
There are several steps involved in unpacking your particular color printer.
I'm sure you have the quick start guide which provides very nice photographs of how to remove the packing tape and materials within the printer, but just in case:
http://www.ricoh-usa.com/downloads/manuals/printers/c410dn/manuals/Quick_Installation_Guide.pdf
I hope this helps.
In the odd case that everything is clear and you still get paper jams, take it back and have it replaced before your 30-day or whatever exchange warranty runs out.
Good luck. Keep us informed.
May 22, 2009 | Office Equipment & Supplies
Paper Jam
There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Mp2050c
The problem sounds like a difference in the settings between the two drivers. Can you compare the two drivers' properties? Maybe the server's driver is set for different spooling options. Is the server handlilng other functions at the same time?
Feb 06, 2009 | Ricoh Aficio SP C410DN Laser Printer
Paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Dec 23, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN Laser Printer Logo
198 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
