Question about Compaq Pavilion ZV5120US (DZ329U#ABA) PC Notebook
Startup/Shutdown At startup the computer (Compaq zv5210) gives an error message of ATTENTION No Signal it also gives the same message when shutting down the computer.
  • Sigrid Gray Feb 20, 2007
    yes I have attached a new monitor HP Model w196 to my laptop and how can I prevent this message from reoccuring
    yes I did add a new monitor HP model w196. How can I prevent this error message from reoccuring
    Scholar:
  • 113 Answers
Have u attached a external monitor to the laptop?
Posted on Feb 18, 2007
  • Sandeep Bakshi
    Sandeep Bakshi Feb 22, 2007
    Do you use the key combination Fn + F4 to enable the external VGA port?
How we enter the hp compaq Ml-350 server bios setting
At startup before OS is loaded you will be prompted to press F8 to enter system setup at this point press F8. This message only last a few second. If you didn't get it the first time reboot the system and pay attention to get this message.
May 24, 2010 | HP Compaq ProLiant ML530 Server
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    A system shutdown notice appears on the monitor that i can't delete
    assuming that u r using win xp pro sp2..
    hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, however, without updation a full version antivirus is useless)..
    download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
    download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
    remove all unnecessary software from add/remove programs..
    download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
    disable the follwing: a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart; b) 'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
    to hv better supervision try contacting ur system admin/vendor....
    Nov 06, 2009 | Computers & Internet
    Model c6180 printer gives improper shutdown error
    The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
    First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
    Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Receiving message wellconhiddenwindow at computer shutdown
    "Receiving message wellconhiddenwindow at computer shutdown"
    Could you give us more info on the error message.
    You can try the following step in the mean time
    1. click on start
    2. click run
    3. type msconfig in the box and click ok
    4. click on the startup tab on the top right
    5. click on the disable all on the lower bottom
    6. click ok or click close
    7. Click restart
    8. Once you are back on the desktop click on the check box , donnot display this message again
    Sep 12, 2009 | Dell Inspiron E1505 Notebook
    My sony computer reboot and shut down by it selt
    right-click My Computer, and then click Properties
    Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box
    Clear the Automatically restart check box, and click OK the necessary number of times
    restart ur pc and see take effects
    Jun 22, 2009 | Compaq Presario SR1703WM PC Desktop
    Computer restarts on shutdown
    If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
    1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
    2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
    Thanks & Regards
    Nandu :)
    Mar 25, 2009 | MSI Computers & Internet
    Problem with shutdown
    Is there any error or the System hang out during Shutdown!
    You can do one thing disable the startup items from the msconfig.
    Go to start -->Run-->Type msconfig --> open the startup tab -->uncheck or disable all items listed here.
    If you face any difficulty add more details, so we can further investigate the problem.
    Regards
    Ellin
    Oct 06, 2008 | Compaq Presario 5000 PC Desktop
    For solving blue screen error
    HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
    Description
    Windows XP may not start and the following error message may appear on a blue screen:
    This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
    An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
    Solution
    If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
    If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
    use the link to know how to use recovery option with hp laptop
    http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
    _____________________________________________________
    Thanks and Regard
    dilipbagdi
    Technical Associate
    May 18, 2008 | HP Pavilion dv9000z Notebook
    Compaq Pavilion ZV5120US (DZ329U#ABA) PC Notebook Logo
    49 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Lee Durbin
    Lee Durbin
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
