Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer is not getting cool
The freezer is not getting cool enough to freeze the meats. Also, not getting cool enough to make ice.
    Scholar:
  • 82 Answers
Hello.
The first thing you need to do is take out the bottom drawer in the freezer and look into the slots in the back panel. Make sure that you can see silver coils, and not a bunch of frost. If there is, then you need a new defrost timer, defrost heater, or defrost terminator.
If this checks out ok, make sure that the coils underneath are clean and the fan is also turning (underneath the unit).
If all looks ok then make sure the fan in the freezer is running. (You may have to push the door switch if yours has one.) If the freezer fan isn’t blowing however, the freezer will be warm at the top and cool at the bottom, and you fresh food compartment will be warm.
Another thing to make sure is that the light it turning off when the door is closed. Again you would have to push on the door switch. I was amazed to learn when I first started this line of work, that even a little light bulb can make enough heat to cause a problem.
Let me know if everything looks ok and I will go over some other things, as the list of things that can go wrong with a refrigerator is fairly long.
Posted on Dec 07, 2008
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
Jun 13, 2012 | Freezers
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 05, 2011 | Frigidaire Freezers
Kenmore top mount refrigerator bought new in august 2010 - kept in a heated garage. have not had to use the freezer compartment up until now. we put meat in it and the meat got cool but did not freeze. ...
The refrigerator compartment thermostat may be the culprit. If you can remove it, you can check its calibration with iced water. Make sure you check the fan motor and the fan blade condition.
Dec 16, 2010 | Refrigerators
I don't have a problem but I would like to know how to set my Dandy refridgerator.Its an upright small fridge.the knob only I see is in the fridge part.I don't know how to set the freeser part .There is...
Compact refrigerators that have a freezer compartment do not have seperate controls since they are cooled by the same evaporator and it is not designed to reach true freezer temperatures. It should get cold enough to freeze water for ice. If it were allowed to get much colder there would be problems preventing the refrigerated section from getting too cold. Therefore, you will have to find a setting that provides a good compromize. You should be able to keep frozen dinners and such cold enough to prevent them from thawing but I would not store meats too long in that freezer and ice cream will get soft. I hope this answers your question. - Subdriver
Feb 03, 2010 | Refrigerators
Some items in freezer are not frozen: bread, cool whip, etc. Meat and veggies ARE frozen. any idea?
This is normal for these particular items. They don't "seem" to be frozen but they are fine. If everything else is frozen that should be, like, ice cream, ice cubes, frozen vegetables, then you don't have a problem. Do make sure your freezer is not building up ice anywhere and that the door is completely shut when you close it.
May 22, 2009 | Refrigerators
Refridgerator/Freezer will not get cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Refrigerators
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
  • possible causes:
  1. bad defrost timer/board
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
