Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M100 Laptop fails to boot
My daughters laptop fails to boot passed the initial splash screen that displays the menu options
[F2] for setup, Press [F12]for boot device selection menu.
I have tried bot option but for no result as the computer will not progess passed this option
  • 2 more comments
  • Anonymous Dec 07, 2008
    my laptop has the same problem. it doesnt go past the loading screen, it just shows a black screeen.
  • Anonymous Dec 08, 2008
    My laptop is doing the same thing. What do I do?? PLEASE HELP??
  • clint_minus Dec 08, 2008
    my computer is doing the same thing.. Please HELP!!!
  • mittalengg01 Feb 07, 2009
    i hope keyboard is locked . whatever i press the key beep sound comes
    New Friend:
  • 50 Answers
Trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Posted on Dec 07, 2008
Not shown booting options
f8 or f9 shows the booting option
Aug 08, 2013 | Toshiba Satellite A15-S127 Notebook
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
The laptop won't boot
probably the hard drive in your laptop is gone.
try booting ubuntu in live mode, so without installing it.
when the boot is completed, launch the tool gparted and see if it detects the hard drive: if it doesn't, you need to change the hard disk..
Jul 30, 2017 | Toshiba Satellite C655D-S5044 15.6" 2GB...
How do i factory reset my m100
If the rescue partition is still intact, pressing F8 as the laptop boots up will show a menu system that gives you the option to restore your system.
Mar 07, 2011 | Toshiba Satellite M100 Notebook
My Toshiba Satellite A215 S4807 laptop will not go pass the opening "Toshiba" page. I can't even get to the set up menu, can someone please help me. It does not respond to any of the F2, F12,...
try holding f8 key while it booting and it will take u to a boot options screen and select last known good configuration and if everything is alright with harddrive and operating system it should boot to windows
Feb 05, 2011 | Toshiba Satellite A215-S4807 Notebook
I can not boot my satellite L 300.I try almost everything and after turn on only screen with "toshiba leading inovation and after this just black screen
As you boot the laptop, press the F2 button when it displays start up options.
When you are in the menu arrow through to the last screen where it asks you whether to save default setting, select default and press F10.
Make sure there is no disk in your DVD ROM drive and go for a re boot.
They seem to latch up sometimes especially when there is a CD or DVD in the drive.
Hope that helps.
Oct 20, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
310 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
