Panasonic NN-H965 Microwave Oven Logo
Posted on Dec 07, 2008
Glass turntable Where would I likely get a replacement turntable for a Panasonic MW model @ NN-H665 WF ?? Thanks
Anonymous
Level 1:
Genius:
  • Contributor 1,199 Answers
  • Posted on Dec 07, 2008
Anonymous
Contributor
Level 1:
Genius:
Answers
1199
Questions
0
Helped
391024
Points
28
PANASONIC WILL SELL YOU THE PART ALL YOU NEED IS YOUR MODEL NUMBER
Panasonic Oven model No NN-C784MF/WF
I would keep the items in. Usually, oil is sprayed on which can cover anything that is in oven at that production step. Won't hurt anything one way or the other.
Panasonic microwave model NN-H965WFX. Turntable will not come on. It turns manually and I can hear the gears turning. Tried taking bottom off but it appears involved so I will wait for your advise. Be
The first thing I would check is the couplet.
Remove the glass tray and pull the couplet up. Check it for any cracks.
If the couplet is fine then the turntable motor has to be replaced.
It can be easy replaced after the bottom panel removed - just two screws and the wire plug.
Hi, my panasonic nn-c784mf stop spinning, seems like the bolt at the center is stuck. Any solutions? Thanks!!!
If you are talking about the turntable with the glass plate that is not working. It is caused by a defective turntable motor, the only solution is to have it replaced, but considering prices as they are probably better to replace the microwave oven.
1helpful
What is the dimension of the rotating plate I broke mine
Here is a link to the replacement glass cook tray for your Panasonic NN-S961 microwave:
http://microwaveglasstrays.com/shop/panasonic-microwave-glass-turntable-plate-tray-f06014m00ap-p-156.html
And here is another link to that part from Sears Parts Direct:
http://www.searspartsdirect.com/partsdirect/part-number/Panasonic-Parts/Microwave-Parts/F06014M00AP/0022/568/Model-NNS961/0789/0123245?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50019470&diagramPageId=00001&productTypeId=x&searchModelNumber=NNS961&subCompDesc=Cabinet%20parts&brandDesc=PANASONIC&modelDesc=MICROWAVE&blt=11
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
As you can see from the website, the tray has the following dimensions:
Glass tray measures approximately 16 1/2 inches in overall diameter.
Outside diameter of turntable track is 10 7/8 inches.
I hope that was helpful to you, good luck and take care.
Joe.
How can I replace the glass turntable tray
These guys are great-----------------follow this link
http://www.appliancepartspros.com/Appliance-Parts/Microwave-Parts/Microwave-Glass-Turntable-Trays/index.aspx
2answers
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
1helpful
I have a microwave oven i purchased jan/07.Themodel#nn-s605wf,serial#6BN6040597,. mY TURNTABLE will not turn can you tell me why.THANKS
Remove the glass turntable, then the roller ring. Then seta glas of water in the unit and turn it on for 5 to 10 seconds. Look through the door window and see if the drive hub is rotating. If it is, then check the underside of the glass table to match up the drive hub. If it isn't turming, the drive, then it is internal and should have a 1 yr warrantee minimum. Remember, the, the turntable and drive must engage each other and the roller ring in place. Good Luck, and let me know please. One more thing, make sure there isn't a Turntable on/off swirch set in the off position. Good Luck, Ne
Find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. Here;'s a photo of that, too.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
