Question about Canon PowerShot A70 Digital Camera
I cannot see the image that I am about to shoot on the lcd screen
The screen is blank however you can see the menu codes only on the lcd monitor in the camera mode. The the replay mode I can see the previous photo that reside on the memmory card
    Master:
  • 383 Answers
The iris is not opening as it is stuck ... it happens due to dust or moisture ... a repairman wud b able to help you..
Posted on Dec 07, 2008
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
Tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
I have a blank screen so can not use it to take a picture
Are you able to see old pictures and menu?I mean when the camera is in non-shooting mode .If so then blank screen generally appears due to the problem in CCD which is the general technology used in imaging devices.
If it is blank all the time and there is no display then the problem is with your LCD screen .You should change that.Please get back to me in case you need any other clarification
Mar 07, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
I have a IBM L151 LCD monitor which is 2 years old. recently while starting all of a sudden the monitor started displaying images in green color only. Secondly the horizontal images get restricted to half...
-try the monitor on another computer and see if it will be having the same problem
-if same problem w/ a different computer it need repair
-if not the computer that you are using w/ this monitor has a problem w/ the video card --try reinstalling the video card driver
cheers
Feb 25, 2011 | IBM ThinkVision L151 15" LCD Monitor
I have the FPD2275W for 5 years but now it only turns on for a few seconds than goes blank but I can touch the menu options on the side and they make sounds but nothing appears on the screen....Help?
New 19" LCD monitors are as low as $100. Buy a new monitor, or pay a qualified technician $50 to $100 to _try_ to trouble-shoot your current monitor.
Apr 07, 2010 | Gateway FPD2275W LCD Monitor
Canon EOS 450D Can only get the Shooting Setting Screen no image
In picture taking mode, press the "set" button for "live view".
Feb 27, 2010 | Canon EOS 450D Digital Camera
Can not get dates to show up on photos
You can embed the date on image data when (Postcard) is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Jul 27, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Monitor problem
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what is the problem of your LCD monitor. After you turned PC on and monitor stopped working or went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. You don't need to do anything with the inverter board in this case. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 20, 2008 | Gateway FPD1975W 19" LCD Monitor
LCD monitor does not light up, and consequently, does not display any image (as some other digital cameras do) during the aiming and focusing processes - sort of prescanning the image - before the shutter...
to my knowledge digital slrs aren't supposed to show you the image on the screen before you shoot because the battery would get used up too quickly this is what the viewfinder is for and the lcd is purely there to tell you info on what the settings are and to view your pics after shooting, I have the 400d and its the same for that.Hope this helps
Sep 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot A70 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
