Question about Maytag Neptune MAH5500B Front Load Washer
Draining Neptune when s dead
Our Neptune 5500 Died on us. we want to unload it without causing a mess. is ther any way other than taking it out of the front door.
    President:
  • Maytag Master
  • 2,651 Answers
Thats about it, shop vac, or buckets,
Posted on Dec 07, 2008
After the final spinn cycle ther is still water in the washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Battery keeps draining
if your battery died while driving and the car cut off while your driving,, your problem is from your alternator!!!,, on a normal working car, you can start, remove ther battery terminals and the car would still run cause the alternator will be powering the car. In your case the alternator isnt working and the car was working on battery power therefore when the battery went dead the car cut off.. Your alternator need \s to be charging between 13.5 and 14.2 volts.. as little as 10 volts will keep the vehicle running.. I'd suggest you have the alternator replaced.
May 06, 2010 | 2003 Chevrolet Impala
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do i remove the back of my 5500 neptune shell?
you dont. it is serviced from the front. open the door, there are two screws on each side in the door frame, remove them (the door will stay without the screws until pulled up and out). pull the front panel toward you from both sides, then pull up out of the brackets on bottom. you can service any part in the cabinet from there. if you are removing the drum, youll see one screw on each side holding the top down, remove and top hinges up and out of the way. shane
Aug 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My maytag neptune washer is very very loud -- I just moved and hooked it up -- it has never been loud before, but is so loud now that it hurts your ears to be in the same room. could this be a bearing...
IT WELL NOWN ON THE NEPTUNE THE BACK BEARING GO OUT AND IT VERRY EXPESEVE TO FIX YOU WILL NEED THE OUTER TUB AND THE TRYPOT ON THE INER TUBE PARTS GO GO UP TO $500.00 THE OLY THIG YOU CAN DO TRY TO PUT OIL ON THE BACK TAKE THE BACK CAVER THER ARE 4 1/4 SCRES AND IN BACK OF BIG PULLY ON PLASTICK HOUSING THERS A SMALL HOLE PUT ANY TIPE OF OIL
Jul 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dead. Power is connected, wires are in tact. Just died when I was using it. Is ther an internal reset?
Try to plug something else into the outlet, just to make sure that the breaker didn't trip.
Try to run the sander without a belt. It may be in a bind.
With the sander unplugged, check the motor brushes. Replace if necessary.
If everything above checks out OK, you may have a loose wire.
Regards, --W/D--
Jul 13, 2009 | Ridgid 3 X 18 Belt Sander
No pressure
Unloaders fail due to carbon deposits on seat. Unloaders can be found in the head or in the tank. Failed unloaders /check valves cause the motor to strain but rarely prevent pressure from building. Events that prevent pressure from building are as follows: restricted intake; cracked or dirty valves in the head; gaskets torn or burned causing pressure to be redirected into the intake. Root problem is caused by carbon deposits and heat. Carbon can be formed if oil is drawn into cylinder due to worn rings or the wrong kind of oil is being used. Compressor oil is formulated to prevent carbon. Engine oil will cause heavy carbon deposts. Replace gaskets worn or broken valves and bad check valves to restore pressure. enjoy
Nov 04, 2008 | Ingersoll Rand Type 30 Electric Driven Two...
Not spining and water not draining off
check filter and check for foreign object stuck in pump impellor
Sep 25, 2008 | GE WSXH208A Front Load Washer
2003 Impala - mystery problem???
you have something thats staying on with power when you shut the car off,first check all lights glove apartment,underhood,in trunk ,just because ther closed doesnt mean the light is off,check your car at night it might help to see the lights,if not another way is to take a multi meter to the battery and while some holds the meter pull out fuses in your fus box one at a time to see when the meter makes a change,this will help you to narrow down whats staying on and draining the power from the battery,if this helps please give me a fix ya vote
Jul 14, 2008 | 2003 Chevrolet Impala
Maytag Neptune MAH5500B Front Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
