Question about RCA 27F500TDV 27 in. TV/VCR/DVD Combo
DVD'S PLAT IN BLACK&WHITE ONLY!!!
DVD PLAYER OUT OF NOWHERE STARTED PLAYING DVD'S IN BLACK & WHITE ONLY,vhs IS FINE AND TELEVISION IS FINE??????
Hey lindalu if you and i put our tv's together we might have one whole working tv/vcr/dvd combo that plays in color! Seriously though, i feel your pain. RCA i'm not impressed.
Posted on Sep 07, 2007
How do I connect an external DVD/VHS player to an old Coby Cx-Tv1 television with no RCA cable?
It should have also an Audio in jack . Take a photo of it and go to some radio/tv parts shop for a converter. They know
May 17, 2015 | Coby CX-TV1 5 in. Portable Television
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
We have a new VISIO HD TV. We have a Sony DVD/VHS combo player. Tried playing DVD and picture comes up in 480 dpi, in black and white instead of color and you can see pixels.
Assuming that there is no issue with the brand new TV or the DVD player....
1. Black and white issue could be due to a misrouted video component cabletomcattech17.jpg
2. The pixels could be just a problem with the low resolution that the DVD may be putting out or the current aspect ratio setting.
Jun 10, 2011 | Televison & Video
My Samsung DVD player has started playing black and white
my samsung dvd is now playing in black and white only.
please help me fix this problem
Jan 13, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
I am trying to hook up my vcr and my DVD to the 60pp9202 60 in my DVD is working but my VCR is not. I am getting a black and white picture on one channel and sound on the other.
put the dvd plug scart into the spare scart socket on the vhs player,then u can only use one player at a time,ie if watching dvd put vhs player into standby or vice versa,the other scart socket on the vhs player goes to the tv. when not using either be sure to put both on standby.
Feb 28, 2010 | Philips 60PP9202 60" Rear Projection...
My DVD player is playing only black & white, colors have gone what should I do?
see if you television works fine. if yes, check the wires of the player see if they're connected properly.if the video is still in black and white.
Feb 27, 2010 | LG DE9523P DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
DVDs on my Sony SLV-D350P DVD/VHS player play in black and white
First try a good quality dvd cleaner. If that does not cure the problem then the video cable may have went bad. I had a system that the cables were never touched & after a few years it needed replaced in order to get my picture back. Hope this helps & please take a moment to rate my answer. Thanks.
Feb 08, 2009 | Sony SLV-D350P DVD Player/VCR
RCA 27F500TDV 27 in. TV/VCR/DVD Combo Logo
208 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
