Question about HP Office Equipment & Supplies
I just purchased an HP Photosmart C7200 All-in-one printer, loaded the ink cartridges and the screen says the magenta cartridge appears to be missing or damaged. I put in a new cartridge- same message shows on the screen. Before I take this thing back to Staples is there anything else I can try? Gary ggg@cros.net
    Guru:
  • 731 Answers
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
rizwan84tx@gmail.com
Posted on Dec 07, 2008
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
Screen says "the following ink
I am having the SAME problem!! The cyan color for some reason!!! All of these are BRAND new HP ink cartridges!! Have you figured out how to fix this??
Feb 21, 2011 | HP Photosmart D7560 InkJet Printer
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
My hp photosmart d6160 printer is not printing black. I have replaced the black cartridge with virgin hp ink. What can I do?
my hp photosmart d6160 printer is not printing magenta.
I have replaced the magenta cartridge with virgin hp ink.
What can I do?
Oct 07, 2008 | Office Equipment & Supplies
Ink cartridge problem
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Aug 11, 2008 | HP Photosmart 8250 InkJet Printer
488 people viewed this question
Ben Johnson
