Question about Mitsubishi WS-55807 TV
Mitsu 55'' screen
Recently, when turning on my 6 year old WS-55807, the horizontal edges of the picture have begun to bow inward from the middle about 4 inches. Coloration is fuzzy throughout the screen. The condition clears itself - usually within 10 minutes of so, but I know it is a sign of a permanent condition to come. Is there anything I can do myself to fix this issue and avoid the inevitable?
  • KDL1 Jan 11, 2008
    I have the same problem as described here, same model TV. It is very intermittent and it will clear itself, but I know it is preparing itself to probably have a permanent condition. Was this issue resolved by owner or by a service call? I am willing to fix it myself if it is fairly straight forward, but if complicated I'll consider a service call depending on the cost of repair.
    Novelist:
  • 192 Answers
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs (STK392-570), have a basic knowledge of electronics and be able to use a soldering iron.
Posted on Feb 18, 2007
Horizontal bowed lines
Since when you experience the problem? what is the first initial problem before you got that one now?
Thanks
pincer
Mar 20, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 Horizontal line in screen, no sound
it sounds like you may have a faulty frame chip. but could be capacitor. who knows for shure, exept an engineer?!?!?
Jul 19, 2009 | Mitsubishi WS-55807 TV
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
Tv bows
I have the same TV and just finished having my TV repaired for the same problem. I was unable to converge the colors even in the advanced convergence setup menu. The lines were bowing so far that adjustment was not possible. I had to replace the vertical and horizontal convergence controllers located on the main electronics panel. They require a lot of soldering and should be done by a professional. Unfortunately this is a common "maintenance" repair that happens every 5-7 years, depending on the usage, costing around $500.00 for in home repair. DO NOT USE YOUR TV IF THE CONVERGENCE IS BAD AS IT MY CAUSE THE POWER SUPPLY TO BLOW resulting in addition repair costs.
Sep 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws 55807
Good Day;
It sounds like your TV is experiencing a CONVERGENCE CIRCUIT failure. YES, it is worth repairing, it's a great TV. The cost will be from $450.00 to $650.00; call an Authorized Service Center and have them give you an estimate B4 repair. Good luck, big IRISH. PS: It's Not An Easy repair to do your self.
Sep 08, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 hour glass shaped picture
If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual and try by yourself see link
Mar 04, 2008 | Mitsubishi WS-55807 TV
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Edges of Picture & Text Sloping
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Mitsubishi WS-55807 TV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
