Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have a frigidaire package heat pump,in heat mode it goes into defrost everytime it runs for a few minutes,no matter what the outdoor temp.is..it runs about five minutes or so and goes into defrost for about two minutes.
  • Anonymous Feb 11, 2009
    i had a hvac guy come out and tell me my defrost board was burnt we have not had the money to fix it but he said it was coverd by warranty just cost of labor hope this helps
  • 334 Answers
That is usually caused by either lack of airflow through the outdoor coils. (Dirty coils, need cleaning)
Bad defrost board. (needs to be diagnosed with multimeter and extensive explinations and/or experience to be sure)
Low refridgerant, causing premature freeze up and in turn causing frequent defrost cycle. (Recharge to proper pressures with proper refridgerant type. Requires EPA certification for use of refridgerant, you would also need refridgerant guages, temperature reading device, and refridgerant.)
Posted on Dec 07, 2008
Gas oven doesn't get hot enough
Good Morning Friend,
I understand that your Frigidaire oven will not heat to temperature if you set it to 350 degrees. I see that you have to set it to 450 degrees for it to heat up, and then turn it back down to the desired temperature. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock and try setting the temperature to 350 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
On my frigidaire 30 self cleaning stove i set the temp at say 350 deg and it will start but will only heat to 280 max no matter what it is set to is there fuses to look at
There is a chance that either the thermostat probe is faulty,if you have an ohm meter the probe should measure about 500 ohms at room temp.if the ohms are good then you will need to replace the electronic contol board
Dec 11, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have an identical problem with a FEF352CATB.
There is a possiblity the oven thermostat may have to be repaired or replaced
Sep 01, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
WILL NOT CONTROL TEMPERATURE
there is some adjustment in the switch to control it but according to ur problem the switch is weak though if u adjust the switch it will work properly only for few days or few months instead u can change a new switch to fix the problem permanently
Jun 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
OVEN TEMP STUCK ON 100F
check your house connections to the stove turn the breaker off first then reply to me
Jun 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
83 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
