Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
HOOVER SAVVY This is less than a year old (yep, no receipt) and all of a sudden last night the vacuum turns off after a moment of running. Also the red and green lights do not work at all. I've thoroughly cleaned the bagless unit, and it still won't work. It powers on for a split second then turns itself off. Help please.
I had the same problem. Took it in and the repair shop they said it was the switch. It was an $18 switch and $30 labor. Switch was a red on/off button with 2 wire leads and caps to screw on for connection. If you can wire a ceiling fan then this looks about the same difficulty.
Posted on Sep 20, 2007
How do i remove the rewinder on a Hoover UH70120
Since you felt the need to ask this question, you are obviously not qualified for this level of repair. Take it to your local vac repair shop. If you have had your machine for less than 1 year it is still under warranty. If it is over 1 year old it is probably not worth fixing. New Hoovers are designed to last only one year and toss them ( as are most all bagless vacs for that matter ).
Jun 25, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Agitator bar on UH4700RM wind tunnel doesn't turn
Unfortunately you machine is a re manufactured vacuum and has a 6 month warranty. (The RM suffix indicates this ) You should take it to your local vac shop and let them look at it. It's probably a minor issue.
Aug 08, 2017 | Hoover U6630-900 WindTunnel Bagless...
Spinbrush is very loud, barely sprays, spraks flew out the side. It is only 6 months old.
Hope you kept your receipt! That's a warranty item. Your motor is making the sparks. Go to hoovers website find the nearest service center and take the machine and your receipt to them. You'll get a new motor, installed, at no charge because they have a 1 year warranty.
Jan 18, 2013 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a S3765 Hoover Wind Tunnel with a crack in the hose close to the cannister. I know wires run through the hose and that there are wire connections on either end of the hose. The replacement hose...
If the vacuum has been maintained properly and runs well it may be worth repairing. The hose is pricey but less than a new vacuum. Many new vacuums today, especially lower priced ones are very poor quality and don't last much longer than a year. It appears by the schematics of your model you can replace just the hose section or the entire hose assembly. Replacing the hose only would require removing the ends of your old hose and installing them on the new hose.
Sep 28, 2017 | Hoover S3670 Bagged Canister Vacuum
Vac will not come on?
If it's less than 30 days old take it back and go get a good vac from a vac store. If it's 9 months to a year old, it's probably got a bad motor. It was made in China, and built to fail in one year. Buy a Riccar. Made in America and built to last for 20 years
Apr 30, 2010 | Hoover U8315960 Bagged Upright Vacuum
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Dirt Finder (light) not working
Good be a bad sensor, but if less then a year old, it is under warranty. I would take it in to a warranty repair shop and have them fix it.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
99 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
