Question about Frigidaire FRU17G4JW Refrigerator
Refrigerator door won't shut
All of a sudden the refrigerator door (not freezer) will not shut (Frigidaire). I can swing closed up to about 6 inches to the frame. It's only my 19 year old and she did or I did not hang on it. There is nothing obstructing it. I can force it shut, but bounces open again!! We just went shopping today. I'm going to have to baracade the door to keep it shut! Help!
Thanks,
Lisa
  • adivinedesti Dec 08, 2008
    Thank you. I found the problem. There was a double hing at the bottom of the refrig door that had a screw that worked its way up, preventing the door from closing all the way.
    Thanks for your help!
  • 334 Answers
Check to see if the door gasket has forzen water that is preventing it from collapsing like it should and wedging the door open. This would most likely be on the hinge side of the door.
Also make sure the gasket is not bent or warped and binding as it closes.
Let us know if you find nothing wrong there and we can look further.
Posted on Dec 07, 2008
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Refrigerator problems 2-door freezer door stuck will not open
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
Mar 01, 2015 | Frigidaire FFHT1715L 16.5 cu. ft....
Amana Br22tw refridge door won't stay closed
Check all the screws for the hinge and be sure the door is lining up properly.
Oct 23, 2012 | Amana ABB1927DE Bottom Freezer...
Refrigerator not cooling FRS22WNC
the damper vent door between the freezer and refrigerator isn't opening to let cold air into the refrigerator compartment from the freezer side,its in the upper left corner in the refrigerator behind a grille,if its closed you wont feel cold air flowing in from the freezer sometimes you can shine a light in this area and look in the other compartment and if no light then the doors shut and this is why its not cooling the refrigerator
Sep 29, 2012 | Frigidaire FRS23H7C Side by Side...
I have a combined Bosch fridge/freezer unit. It is the frost free type of freezer. Lately, the bottom unit (the freezer), the door sometimes seems to have no pressure behind it and will not stay shut.
use a level to make sure unit is not tipping forward. adjust 2 front feet to tip slighly backward door will then close itself from about 6 inches......poss feet have sunk into floor covering.....
Feb 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
Refrigerator, is cool but not the least bit cold, even on the
There might be something logged in between the doors. Check really good
Jun 30, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Mar 28, 2009 | Frigidaire FRS26R4A Side by Side...
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Frigidaire FRU17G4JW Refrigerator Logo
935 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
