Sony kdf-55e200 willony display high defination signals all other have audio only
  • 505 Answers
If only high def comes through, you have a doubler problem. all inputs that arent hd need to be scaled to 1080 to be displayed. if only hd works, your problem is the double = b board
Posted on Dec 07, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
I have a sony wega kdf 55e200. When i turn it on i get maybe 4 green flashes of the power light, followed by 3 red flashes. I've already spoken to tech support and they've explained to me that it means the...
Tries unplug,replug tv an hour later,that a reset tv back to factory setting.See,that solved ur problems.Not, than the lamp u have might gotton shorted some how.Buy a another lamp.Tries the same process.
Sep 17, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Sony wega kdf-55e200
my question is this. our lamps keep blowing in the tv, I need to know if I can replace the fan myself or does it need to go to a technician? if I can do it then where can I find the part? I have been searching the internet and cannot seem to find anything but a lamp replacement!!
Mar 09, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Audio stopped working with my sony kdf-42we655 tv.
Reset the Audio back to factory setting.Should work, some wrong setting in ur setting.
Jan 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Unstable signal on a SONY KDF-50E2000 08760591
Can you please explain what you mean by an unstable signal? Without details, the problem can be anything from a weak signal being presented to the tuner to a defective tuner to poor signal processing later on. Also, check the picture and sound using different inputs to the set. If hte problem is the same regardless of hte input signal, that tells us that the problem is in the video signal processing circuitry. Also, place a menu on the screen. Is the instability present with the menu display?
Thanks,
Dan
Nov 04, 2009 | Sony KDF-50E2000 50" HDTV
Sony wega kdf-55e200,
If you get just lamp without housing be very carefull you do not put your fringers on Lamp it will leave print and burn into lamp wear plastic gloves to replace this way
Sep 06, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Screen
yes you can remove the screen by removing the front plastic trim and the removing the screws that hold the screen in. clean the screen and put it back together.the front plastic trim should just pop off
Aug 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
