Have a small drip at quick disconnect on tank 2002 harley ultra can o ring be replaced without pulling tank or do you have to replace fitting?
SOURCE: Harley Davidson Ultra classic handlebar replacement
1.cover the tank with towls beachtowls 2.remove switches,unbolt both ,clutch and front brake from bars,leftside grip pry under it with a flat crewdriver and spray under it with hairspray and turn on it to make it come off, right side loosen the bars and move them so when you loosen the rightside it can come right off.unbolt the bars from center of the bars
SOURCE: removing harley davidson ultra classic gas tank
Drain the fuel either by siphening or removing the cross over tube at the front of the tank and letting it drain that way or just block off those cross over lines and leave the fule in the tank for removal.
0) remove seat
1) drain fuel
2) undo cross over line (bottom front of gas tank.
3) shut off pet **** and remove fuel line from pet ****.
4)there should only be 2 bolts holding the tank on, one at the top front of the tank and one at the back of the tank.
All in all a pretty easy (but possibloy messy) job.
SOURCE: will a gas tank off a 5 harley dyna wide glide
It sure will!! You answered your own question. guess i get no points for this one.
SOURCE: 2002 harley davidson ultra classic setting the clock
Turn the Bike on and the Radio off and then follow the buttons on the screen. Most people think you have to do it while it is running and this does not work
