Question about Sony SLV-N750 VHS/S-VHS playback VCR
I need a VCR-Head Drum (New) for my Sony VCR which has got SP/LP
My VCR is not playing good, however I have cleaned the head, but still only audio is comming fine, but the vedio not alt all comming just blue screen or some time some blank screen with doted lines.
Do any one got VCR head drum for my Sony VCR (SV Model)
Thanks
Venkatji
    Master:
  • 383 Answers
Check the Video Output Flex .... Sumtimes if its broken it creates that problem
Posted on Dec 07, 2008
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Apr 27, 2012 | Sony Televison & Video
When recording in any speed other than LP, picture becomes very fuzzy and eventually blue screen will come up and say "heads may need cleaning". Cleaning never helps, but in LP mode rarely have a...
most of these units use two sets of video heads on the drum===one set for sp/slp and another for lp;
Get someone to open it up and carefully wipe the video heads----You Tube used to have video instructions for this, pretty simple stuff.
Cleaning tapes never work---if cleaning does not correct it---you have a bad video head.
SD TECH
May 13, 2011 | Panasonic PV-8451 VCR
Vcr wont play properly tracking seems to be off i have opened up the vcr player and given everything a good inspection but cant see any obvious issue with the ''mechanics'' of the device. The tape being...
It is possibe that the guide of the tape transport is gone a little off. This can happen if the guide has not loaded properly. check inside for obstructions to the link. if not try to screw down the half split screw a little down on either side to release the tracking/ noise onthe screen. Also clean the tracking head which is also the audio head. clean your roller if this is holding down the tape. Please do this with caution and care. clean your head and also the lower section of the head drum for dirt. you will see accumulation on/under the lower drum , Hope this helps. Good day
Jul 10, 2010 | Sony SLV-940HF VCR
I HAVE A BUSH VCR/DVD COMBI WHEN I RECORD ON LP IT PLAYSBACK ON SP AND LP ALTERNATIVELY
This sounds like dirt on the heads. Try cleaning the Main Video head the audio/tracking head and anything else that where the tape touches, with Servisol Video 40, from Maplin or Radio Shack etc.
Sep 14, 2009 | Televison & Video
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
No picture
I assume this symptom appears when attempting to play a tape? If the picture is mostly snow, VCR may need video head cleaning. To do this, take the top cover off- You will note a cylindrical shiny aluminum drum- the actual heads are at the lower edge of this rotating drum.
Anyway, use a lint free cloth or special wipe moistened with rubbing alcohol, or product specifically made for such, carefully cleaning those heads as well as the drum itself. Occasionally, it may take 2 or 3 cleanings.
If the VCR has lots of hours, or abrasive head cleaners have been used, the head could be worn out. If so, toss the rig and purchase a new one. Head replacement is non-economical unless you have a high end machine.
Jun 12, 2008 | Sony SLV-R1000 S-VHS VCR
Switched back and forth between SP and LP in playback
The control track on the tape is not being sensed properly, or there may be a fault in the capston circuit, or capston drive.
There are a number of issues that can cause this:
This can be a dirt film on the control track head, or the main video drum heads, or warn head surfaces. It may also be an alignment problem due to warn parts. The electronics that read and process the control track, or video synchronization processing may have a fault.
The first thing you can do as a user is to clean the tape path. It is safest and usualy works well to use a cleaning tape for your camera type. Follow the instructions for the cleaning tape. The cleaning tape has a surface on it that is supposed to clean the head surfaces without causing a disturbance. Usualy the time required is about 5 to 10 seconds, depending on the model of the camera and the type of tape format.
Read the instructions that comes with the cleaning tape. It is not recomended to re-wind and re-use this tape.
Past this point, the camera will have to be serviced.
Jerry G.
Mar 24, 2008 | Sony Handycam CCD-TRV318 Camcorder
Older VHS tapes play 'sped up' on S-VHS
A couple of possibilities: 1. One of the machines had a audio & tracking head alignment problem. If memory serves, tracking pulses are recorded on the bottom edge of the tape, and if one machine's head is slightly off, then these pulses aren't being picked up.
2. Do both machines have 3 play/record speeds? Many machines had SP, EP, & LP. Some didn't have EP, and if your older tapes were recorded in EP, perhaps this would cause your problem.
Both of these possibilities might be way out in left field.
Perhaps you could have a friend try your old tapes in their machine- in short, narrow down the defect. Is it the older VCR and it's recordings, or is it some goofy problem on the new one.
Lastly, you might check the audio/tracking head- see if it needs cleaning. This head is just to the right of the rotating video drum assembly.
Jan 28, 2008 | JVC HR-S3901 S-VHS VCR
Sony VCR plays/recordes in EP mode but not in SP mode - need schematic
sounds like it needs a good cleaning, you will notice this problem in sp first when needs cleaned. however if you had done this I would go over it again and if not then change the video head
Nov 19, 2007 | Televison & Video
Audio
Does it play back professionally prerecorded tapes okay? Does that VCR have a HiFi stereo option? What is the brand name and model number of the unit?
Apr 24, 2017 | Panasonic PV-C1331W 13 in. TV/VCR Combo
Sony SLV-N750 VHS/S-VHS playback VCR Logo
117 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
