Question about Dayton Gas Furnace Heater
Dayton gas furnace
My Dayton gas furnace will cycle just fine and then all of the sudden it will quit. When I reset it, it will normally run fine for awhile. I have watched it a few times when it locks up on me and it appears that the flame will light under the flame sensor and then go out in that section causing the furnace to lock out. It almost seems like it is being blown out.
    Problem Solver:
  • 5 Answers
You may want to change the fenwal auto ignition system.
Posted on Dec 17, 2008
  • Dayton Master
  • 2,096 Answers
Try cleaning the flame sensor and the burner , check out the pressure switch might be blocked in the tubes
Posted on Dec 11, 2008
Trouble shoot Dayton gas furnace model GG9S100C16MP11A fan is left on constant but in cold weather 10 or colder fan will go off and furnace will go thru a restart mode and run fine for awhile then will do...
Do not run contentiously during heat mode. the fan runs at a slower speed with heat and heat fires first then the fan cycles on during heat cycle then when heat satisfies the thermostat the heat will cycle off and fan will run for a couple more minutes and then cycle off. So set stat on fan cycle to auto.
Feb 03, 2015 | Dayton Gas Furnace Heater
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Furnace fan runs costantly
Check to see if fan setting is summer or winter.
Feb 05, 2012 | Dayton Gas Furnace Heater
I have a Dayton gas furnace FG8B07512MU12A. It has a new control board and worked fine for the last 6 months. Now when the fan goes on the air put out is cool not warm. The card shows a slow blinking...
Is the manual gas valve open, either plumbed or on gas valve? It may sound dumb, but it happens. Are the wires connected to the gas flow solenoid securely?
When the heat call initiates heat cycle, can you observe the ignitor? If it tries to ignite, is there gas entering the burner? How clean is the gas orifice? If the orifice is plugged, best to simply replace it.
Dec 18, 2011 | Dayton Gas Furnace Heater
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Nov 22, 2011 | Dayton Gas Furnace Heater
No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Oct 31, 2009 | Dayton Gas Furnace Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Fan continues to run after heating
That's the fan switch. It's a thermostat that controls the fan coming on and off, it's probably failed and needs to be replaced. You can see it if you take the front off the furnace, the wires come off it and go to the fan motor.
Jul 13, 2009 | Dayton Gas Furnace Heater
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
230 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
