Question about Magellan eXplorist 210 GPS Receiver
Computer fails to "see" the 210 when attached by USB
Although the unit says it is communicating with the host computer, the unit doesn't show up on the computer as an external device. It's as if the 210 isn't there. As a result, I can't delete old map sets or enter any new ones. We've tried it with four different computers and with a new USB connector cable, but with the same result in every case.
  • tom_kupferer Dec 28, 2008
    I tried it with XP, Vista and even open source operating system. Same result in every case
I talked with Magellan Support today (12/26/08). Their solution was to borrow a friends Windows XP system. I did and it worked. They DO NOT have a solution for Vista and claim that since Vista came afterwards they are not accountable for making it work on that O/S.
Posted on Dec 27, 2008
Computer doesn't see my ssd
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
Oct 22, 2012 | Crucial Technology 128GB 25inch Solid...
My Lexmark Z816 cannot communicate with comupter. Have worked through troubleshoot to device manager and was told USB Root Hub is fine but USB Host Controler not activated. How do I activate it?
Please follow the steps below to enable USB host controller:
1. On your computer, go to Start menu. 2. Right-click on My Computer. 3. Click on Properties. 4. In the pop-up windows, go to Hardware tab. 5. Click on Device Manager. 6. In the Device Manager window, expand Universal Serial Bus controllers. 7. From the list of USB host controllers, look for any in the list with a warning (?, !, X) sign (typically indicates a missing or improperly installed piece of software). Right-click on the item and select enable.
Another quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
I hope this helps.
Nov 01, 2011 | Lexmark Z816 InkJet Printer
I an not have driver usb for hdd2193 for fix problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you dont have a motherboard disk you will need to download the drivers
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
hope this helps you
Sep 11, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
What does SCSI mean?
SCSI- Small Computer System Interface
It is a set of standards for physically connecting and transferring data between computers and peripheral devices.
May 29, 2010 | Microsoft Windows XP Professional
Xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Aug 07, 2009 | Xerox Office Equipment & Supplies
Usb camera olympus fe-210 not working ,ill try manny times but nothing happens
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Jun 03, 2009 | Olympus FE-210 Digital Camera
PcAnywhere Host Administrator
Hello , the best way I have to solve that problem, is click on this link , they can checking on you device and see what is bad
Mar 12, 2017 | Norton pcANYWHERE 11.5 Host & Remote...
Scanner?
None of the above.
Both the scanner and the printer connect to a computer.
If you care about technical language, the scanner and the printer are USB clients. The cannot communicate with each other. The need a host for that. A computer has USB host device built in.
Jan 04, 2008 | Compaq S4 100 Flatbed Scanner
PC can't communicate with GPS unit for initial map load
It will NOT show up under USB controllers. It should appear as "GARMIN Devices" in your device manager. Mine is right under Floppy disk drives. Do other USB devices 'bong' up when connected and 'bong' down when taken off? Of course you have to have your audio on for that. The GPS should 'sound' just like any other USB device when attached or taken off. I find that GARMIN help is of no use. Forums like this have helped me far more.
Feb 04, 2007 | Garmin StreetPilot C330 GPS Receiver
Magellan eXplorist 210 GPS Receiver Logo
245 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
