Question about Refrigerators
How often do I change the water filter
I received a Kenmore Coldspot, Model # 106.74962400, from a friend, but did not get the manual. My question is how do I know when it is time to replace the water filter? I don't see a light, so I need to know how often I need to do it, and what is the part number for the filter?
  • LAGA5 Apr 17, 2009
    EXCEPT MY FRIG IS THE COLDSPOT 106.9535580.
    I TRIED MY HOME MANAGER, BUT THE SEARCH IS COMING BACK WITH NO RESULTS.
  • 750 Answers
Hello welcome,
here is the site to get and or print out your manual for your Kenmore Coldspot, Model # 106.74962400
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406138.pdf
Thank you , Huum
Please leave a solved rating before you sign off!
Posted on Dec 07, 2008
    President:
  • Refrigerators Master
  • 2,651 Answers
I cant even find a filter on your machine, if there is one, there will be a model number on the filter itself as well as re-order information.Once a yr , you shhould change
Kenmore coldspot model 9552822 bad taste from the water and ice maker
When did you last change the carbon filter? When did you last clean the icemaker? They get a colony build up that is like jelly made from bacteria.
If you changed the filter within 6 months, contact your water utility and ask them to test the water.
May 07, 2018 | Kenmore Refrigerators
Kenmore coldspot 52582201- water filter part number
found it try here...
https://www.repairclinic.com/Shop-For-Parts/a4b6i183d605447/Model-10652582201-Kenmore-Refrigerator-Water-Filter-Parts
Jan 24, 2018 | Kenmore Refrigerators
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Where is water filter located on kenmore coldspot model #52212100
contact sears parts to get a owner manual but filters are usually locate in line before the unit.
www.searspartsdirect.com
Sep 14, 2014 | Kenmore Refrigerators
Kenmore coldspot- 106 Model 9537654
The Kenmore Model 106.9537654 does not appear to have a water filter. Thanks Sea Breeze
Here is a PDF of the parts=> 106.9537654 Parts
Jul 15, 2013 | Kenmore Refrigerators
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
What is the part number for the water filter for a Kenmore Coldspot refrigerator model 106.54209300?
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
May 17, 2009 | Refrigerators
Refrigerators Logo
911 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
