I have white vertical lines thru my printouts, about an inch apart. I have tried deep cleaning and aligning the print head. Problem not solved. What do you think this is about?
  • 1 more comment
  • mrs6319 Dec 07, 2008
    I have an i250 Canon Printer.
    I have deleted and reinstalled my canon i250 printer as you suggested but that did not solve the problem of vertical white lines on the printouts. I have done a deep cleaning and printer head alignment also. These vertical white lines are about 1 inch apart on the whole page. I need more HELP!!!!
  • mrs6319 Dec 09, 2008
    Well, the solution is to replace the printer. I hoped it was repairable but thats' not usually a practical solution since it's not that expensive and basically another 'throw away'. I appreciate the quick response from Canon.
  • 4,472 Answers
I would recommend just replacing the printer as it is not worth the price of repair. You can get a comparable model for as little as 25 or 30$. If you need any help locating a comparable model I will be more then happy to assist you. Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
Posted on Dec 07, 2008
    Genius:
  • 1,239 Answers
Hi It sounds like the drum may need to be replaced. The streaks may be caused by sections of the drum no longer being able to hold a charge and therefore, toner will not properly stick to the paper in those sections and you'll be left with long white streaks on the paper. This is a usual symptom of a bad drum.
I just want to know that which did you try to use to scan. is that by using the ADF (automatic document feeder) or using the scanner glass?
  • 4 more comments
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    try this
    1. Unplug the power cord and the phone line from the wall.
    2. Open the control panel.
    3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
    4. Note: The scan lens is located under the white roller.
    5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
    6. Reinstall the white roller.
    7. Reconnect the power cord and the phone line.
    8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
    Good luck..
  • ABHISHEK.C
    If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
  • ABHISHEK.C
    DID YOU CHECKED DRUM
  • ABHISHEK.C
  • ABHISHEK.C
    Focus in the laser beam pathway, there is some thing cut it.
    Thanks
  • ABHISHEK.C
    I TOLD KNOW IT IS DEFINITELY DRUM PLEASE CHANGE IT,,,,,,,,,,,,
  • 6,487 Answers
Can you please provide us the brand and model of this printer so we can help you better, and also you can try to uninstall/reinstall the printer software and see if that will fix the problem....
  • Mark Gil
    Mark Gil Dec 07, 2008
    If that is the case a print head replacement is needed for this, because the print is already bad....
  • 365 Answers
Is the printer a newly buyed or
  • JITHIN ANTONY Dec 07, 2008
    is the printer a new one or it has been using for many years.
    Genius:
  • 3,422 Answers
Please let me know the make and model no.of your printer.
  • Priya darshan Dec 07, 2008
    I will be waiting for your reply.
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
Missing Column G on print head align printout!
can you please try a test page...and report back what that looks like..
Oct 15, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Got a brand new Pixma 280 here. Have aligned the print head and executed cleanings, reinserted the ink etc, but still there is one area that is blurred on every printout which results in a white vertical...
The Pixma printer allows to make test pages and do maintenance on it.
First go to Start Menu on Desktop at the left bottom Click on it then go to printers and Faxes.
Right click then click on Properties. Then go to Maintenance panel Click on it. Do the Deep Cleaning, Roller Cleaning keep on doing it until it shows you paper that does not leave a vertical white gap. You have to be very patient as this does not go away quickly. You might have to run 20 pages doing this cleaning until that line is gone.
Oct 13, 2011 | Canon Office Equipment & Supplies
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
Let me know if this solves your problem otherwise we can explore other solutiions.
Please rate this solution. Thanks.
Oct 06, 2009 | Canon BJ I6500 InkJet Printer
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Ip4500 printouts have lines through them
I experienced a similar problem when I purchased generic ink off eBay. I did more deep cleans than I can count on my hand, but it did not help. I did the water soaking treatment until there was no more ink coming out of the printhead, but that only made things a *little* better. I finally figured the ink cartridges were bad, so I replaced them. But my new ink did the same thing. So I did the water soaking treatment again. But this time, I forced air through the printhead and actually saw some of the "ink jets" that weren't blowing bubbles out before (when I would blow) begin to blow bubbles. Test results later proved that some of the ink jets were seriously blocked and blowing helped to free them. I do not believe all the jets are free because I still have faded print results, but my results are definitely better! Hope this helps.
Feb 23, 2008 | Canon iP4500 Photo Printer
White bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Mar 16, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
14 people viewed this question
jasbo
jasbo
