For a detailed Range/Stove/Oven illustration, click below.
Gas Free Standing Electric Free Standing Gas Cooktop Electric Cooktop Gas Walloven Electric Walloven
Warning!
To avoid personal injury or even death, always disconnect your
appliance from its power source--that is, unplug it or break the
connection at the circuit breaker or fuse box--before you do any
troubleshooting or repair work on your appliance. Also, because some
components may have sharp edges, use caution while working on your
appliance.
HI.CONTROLS MIGHT HAVE BEEN LOOSE.oR LOOSE CONNECTION BETWEEN the control.Check the control connection inside .It might respond but connection has been loose.hope this helps..
The problem is likely one of two things: Either the lower burner is shot and should be replaced, or there is a defect in the switch. The burner is the more likely problem if the upper burner is still working. If the lower burner works on any of the other settings it could be the switch, which would need to be replaced.
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
gas
