Back to:
Tags:
Acer Aspire T135 PC Desktop
Cant Start
posted by josh101 on Feb 17, 2007
When i start the computer the firs beep goes but then there is a big beeping that lasts for over 30 min i stop after 30 mins the motor fans and power workin but it cant detect the monitor im really suck i was only write on word and the screen went black i restared comp and then that happened, i left it for 3 hours to cool down bu it still not work HELP ME!! i need to fixed by tommorrow plz help
Comment by josh101, posted on Feb 17, 2007
i only have 1 meory stick and i took i out and it did the same but when i took it out it went beep ...... beep......beep. and keeps going
which agp card theres alot
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
sandrew
Rank:Wiz Wiz
Rating: 83%, 5015 votes
Take the side off the computer and remove and reseat the memory, if you have two memory sticks try one at a time,also remove and reseat the Graphics card(if one is fitted)as the second long beep depending on the motherboard indicates a memory or graphics card fault.
If there is no graphics card fitted (card which is seperate to the motherbaord fitted in a brown AGP slot), then you have an onboard graphics problem.
To get around this you will ned to purchase an AGP graphics card and dissable the onboard graphics in the bios (f2 or Del on startup) and in advanced settings set your AGP card as the primary graphics controller
Comment by sandrew, posted on Feb 23, 2007
No, there's only one AGP card in the Brown slot, not the white ones.
If you only have one memory stivk then you can't leave it out as you will get constant memory fault beeps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cant Start:
I don't want to Accept this solution
Can you Help with these PC Desktops problems?
PC Desktops
how can i convert my hp pavilion tx 1327 cl entertainment...
PC Desktops
I have various cable modems RCA DCM 315 made in Taiwan...
PC Desktops
I bought an Actiontec 54Mbps Wireless Cable/DSL Router I...
PC Desktops
lost seriel no of photosuite 7 cant get entry?
Good Evening i have an Acer t135 but i'm having a problem...
Loading problems.
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
