Question about Vulcan EF3 Deep Fryer
Vulcan Deep Fryer, burners shut off, remains off!
The problem that I am having with the LG300 Vulcan Deep Fryer involves the burners getting shut off by the thermostat. When the temperature falls however, the burners remains off, even though the pilot remains lit for awhile it eventually shuts off too.
  • Anonymous Mar 28, 2014
    pilot light working correctly.when thermostat is turned on main burners light,oil comes up to temperature,but as oil cools ,main burner will not re-light
    dean fry master deep fryer pilot light working okay stays lite.when thermostat is turned on,main burners light,oil comes up to temperature,when oil cools,min burners will not re-light,even if the thermostat is turned higher.te pilot light remains lite te whle time
    Problem Solver:
  • 19 Answers
Sounds like your gas valve to me, you need a manometer to test it under gas pressure.
Posted on Feb 07, 2009
My vulcan lg 300 deep fryer latch won't turn what should I do
Some fryer valves have a safety lock, usually a slide on the handle near the valve body that must be released to open the valve. Check for this first. It's very rare for a fryer valve to stick unless it was forced shut with something partially blocking it. If not, let the fryer cool completely. Dip as much oil out as possible. Then disconnect the gas line and, with help, turn the fryer upside down draining the remaining oil into a suitable container. At this point, you have little to lose. Take a large wrench or piece of pipe to get more leverage and try to force it open and free it up. Do not use so much force that you damage the kettle. If you get it free, check to see that it does not leak before putting oil back in the fryer. If it leaks or fails to come free, replace the valve.
May 23, 2014 | Vulcan Kitchen Appliances - Others
My deep fryer is working but once or twice a day the door of the fryer will suddenly open with a thud! Scaring all in the kitchen. If we keep the door open then the problem goes away to some extent. Lot of...
It is advisable to get a qualified technician to clean the burners, pilot, and insure there is proper gas pressure and volume to the unit. Without verified gas pressure and volume, even with clean burners the problem may recur.
Jan 16, 2013 | Vulcan EF3 Deep Fryer
How to clean burners
Hi there.
Cleaning fryer burners is a tough job. It involves literally dismantling the gas train system of the unit and requires some special tools.
May i suggestto leave these matters to the qualified technicians on your area to get the job done correctly.
Regards.
Nov 26, 2011 | Vulcan Kitchen Appliances - Others
How do i calibrate a lg300 gas fryer
I don't know that you can calibrate a thermostat on a deep fryer...Is your thermostat bad? Is the temperature setting off? Is it working at all? You could call Vulcan directly and ask for the parts/warranty dept and they could tell for sure if calibrating is possible or not... If not, and you need a new thermostat, then they can point you in the right direction for a dealer that sells their parts...
If I can help in any other way, call us at 888-542-5959. Thanks, Susan @ Restaurant Equipment Outlet, Cincinnati, OH.... www.restaurantequipmentinc.com
Aug 27, 2011 | Vulcan LG300 Deep Fryer
Pilot light is working in a.m. when machine is started. After machiine runs up to temp (350 deg) the burner will turn off and pilot will go out also. After finding machine has shut off we turn it off and...
Ensure that the gas pressure being fed to the unit meets the standard as rated on the unit's nameplate.
The thermopile must be free of soot or any form of dirt.
Pilot flame quality must be good and can heat up the thermopile properly.
Wiring connectors must be tight.
Regards.
Jun 23, 2011 | Vulcan LG300 Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
I cant buy just the nat gas to lp gas conversion parts for a Vulc
call your gas supplier as they have reasonable sources for all of these parts. shame on vulcan.
Mar 31, 2009 | Vulcan EF3 Deep Fryer
I need to find the pilot light on my Vulcan fryer?
It is usually between the burners, if you cannot find it you should really find someone that can
Feb 01, 2009 | Vulcan EF3 Deep Fryer
Control valve leaking (Vulcan LG300 Propane fryer)
must change gas control valve which will repair leak also
Jul 31, 2008 | Vulcan EF3 Deep Fryer
Vulcan EF3 Deep Fryer Logo
312 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
