GE JRP24 Electric Double Oven
Problem for GE JRP24 Electric Double Oven
Jrp24bow3bb electric double oven control panel.
By rhonm13 on Dec 07, 2008
as i said before, ibought a control panel for my oven and can not see where to connect the gray wire that comes from the oven.this control came new and they say its the right replacement but maybe i am blind because i see no conection for the gray wire.i am using the lower oven only now because the top one does not work without the gray connected.help!
Solution #1
posted on Dec 07, 2008
Somewhat Helpful)
Powerman
Rank: Guru  GE Expert
Rating: 92%, 264 votes
Hi rhonm,
You should have found a connection diagram in the top of the oven. If you didn't, call GE at the following number and they will send you one. 1-800-626-2005
It would be very difficult for any one to make a recommendation without seeing the oven or part. Are there one or two gray wires? My first guess is that they sent you the wrong part. See photo for typical double oven ERC.
Regards,
Powerman
Was this helpful?
Yes
No
Popular Solutions for GE JRP24 Electric Double Oven
Questions and Unsolved Problems for GE JRP24 Electric Double Oven
Do you recommend GE JRP24 Electric Double Oven?
Answer
Answer
I used the cleaning feature on my Amana oven and now the door is locked and will not open. The F9... (More)
Answer
My stove made a loud pop and nothing works on it now. I had my oven preheating to cook then it went... (More)
Answer
my new contol panel for my ge jrp24 wall oven came with directions to install but they do not show... (More)
Answer
Only reaches temperature of approximately 100F. What part do I need to fix the problem?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE JRP24 Electric Double Oven:
Top Oven Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
