Question about Car Audio & Video
Which pins in harness are hot and negative etc.
I just got one of these and it came with no plug, but I need to test it to see if it works can anyone tell me which pins in the harness are Hot,Negative etc.
Thanks its a kenwood Dpx-710 md mini disc player
Usually the red is hot and the black or other is the ground !
Posted on Dec 07, 2008
Working on 2003 Lincoln LS 3.0. code p2110; p2107. Customer replaced throttle body
P2110 - Throttle Actuator Control System - Forced Limited RPM. Throttle actuator control system is in FMEM mode of forced limited RPM.
  • PCM damaged
  • Cross wired TACM motor
DTC indicates only that FMEM condition exists, and can be set incombination with DTCS P2100, P2101, or P2107, meaning the ETB faults should be repaired first.
P2107 - Throttle Actuator Control Motor Processor. The ETC control area of the PCM failed self test. Fault could be the result of an incorrect TP command, or the TACM wires shorted together.
  • TACM wire shorted together
  • TACM circuit wires shorted to pwr
  • PCM damaged
  • ETB damaged
An (TACM) circuit PID reading may indicate a fault if available
DV21 CHECK ETC MOTOR FOR SHORT OR OPEN
  • Remove ETC motor harness connector.
  • Measure the resistance between the TACM + and TACM - pins, through the motor.
Is the resistance less than .8 ohms, or greater than 1000 ohms?
Yes No Replace Throttle body assembly. note: Clear DTCS and rerun self test, if DTCS (P2100, P2106, P2112), or (P2100, P2106, P2111, P2112) are output GO to DV22 , for (P2100, P2106, P2107) GO to DV23 , and for (P2100, P2106, P2107, P2111, P2112) GO to DV24 , and for DTCS (P2101, P2106, P2110, P2111, P2112) GO to DV25 . GO to DV22 . DV22 CHECK ETC MOTOR HARNESS FOR OPEN
  • Remove PCM harness connector.
  • Measure the resistance of the TACM+ circuit between the PCM and TACM harness connectors.
  • Measure the resistance of the TACM- circuit between the PCM and TACM harness connectors.
Is the resistance less than 5 ohms?
Yes No GO to DV23 . Repair open circuit. DV23 CHECK ETC MOTOR HARNESS FOR SHORT TO GND, PWR, ETCREF, AND ETCRTN
  • Measure the resistance between the TACM + pin and battery gnd.
  • Measure the resistance between the TACM - pin and battery gnd.
  • Measure the resistance between the TACM + pin and battery pwr.
  • Measure the resistance between the TACM - pin and battery pwr.
  • Measure the resistance between the TACM + pin and ETCRTN.
  • Measure the resistance between the TACM - pin and ETCRTN.
  • Measure the resistance between the TACM + pin and ETCREF.
  • Measure the resistance between the TACM - pin and ETCREF.
Are both resistances greater than 10K ohms?
Yes No GO to DV24 , for P2101, GO to DV25 . Isolate and repair short circuit. DV24 CHECK ETC MOTOR HARNESS FOR CIRCUITS SHORTED TOGETHER
  • Measure the resistance between the TACM + pin and TACM- pin.
Is the resistance greater than 10K ohms?
Yes No GO to DV25 . Isolate and repair short circuit. DV25 CHECK FOR CROSSWIRED ETC MOTOR HARNESS
Yes No GO to DV26 . Properly wire the TACM per TACM and PCM connector diagrams. DV26 SELF TEST VEHICLE
  • Key On Engine Off.
  • Clear DTCS.
  • Cycle accelerator pedal to the floor and back several times.
  • Self Test vehicle noting any DTCS.
Were there any DTCS related to the ETC system?
Yes No Intermittent fault, GO to Z1 Replace PCM.
Oct 13, 2017 | Lincoln Cars & Trucks
No spark to plugs 1999 ford f150 4.6l
https://s21.postimg.org/wwpncpluf/pcm_power_relay.jpg
Click on the link.
Voltage for fuse 18 comes from, pcm power relay.
Terminal 30, load side of relay is fuse protected and hot all the time. If you unplug that relay and use jumper wire between terminal 30 and 87, fuse 18 should go hot. That should mean, the control side of relay has a problem, The control side needs voltage and ground.
Jul 24, 2017 | 1999 Ford F150 Regular Cab
WHY PASSENGER SIDE HEADLIGHT BULB ON 2007 YUKON DENALI WILL NOT WORK
Remove plug from light bulb, using 12 volt test light hook up ground to negative side of battery,then touch probe on positive terminal to make sure test light is functional.next- turn lights on and then probe the plug at each terminal- there should be one wire that has power and the test light should light up. If the test light lights up then you need to test the circuit ground for the wiring harness. So remove the test light clamp and put it on the positive post of the battery. Now retest the test light by touching the probe on the negative post on the battery and the test light should light up. Next with the headlights off-probe the other terminals and if there is a good ground in the harness the light will light up- if not then there is an open condition in the headlight harness- a broken wire or a bad system ground.If both tests are performed and either condition does not happen then a wiring schematic will be needed to perform the repair. This is after all fuses are presumed good.
Feb 04, 2013 | 2007 GMC Yukon Denali
I have a 2002 mustang gt. my problem is with the A/C clutch not engaging. I have checked fuss and high and low pressure switch. i have also changed compressor and clutch. both are bran new. when i test the...
When you changed the compressor, did you recharge the AC system? If the pressure switches are not actuated by the correct pressure, the system will not engage the clutch. To charge the system you have to pump a vacuum on the system for about an hour. Follow the new compressor instructions as to the amount of oil that may be in it and how much the system calls for. See it has the correct type oil and the correct amount, then charge with the correct refridgerant and the correct amount.
Gaker
Jun 19, 2011 | Ford Mustang Cars & Trucks
Door ajar light stays on when all doors are closed
After long hard research I found the problem to these explorers and f150s etc. Fuse 17 is overloaded with electronics and when the wire that's ran to that circuit gets hot it causes glitches with the electronics. Ford set the harness up to fuse 17 like a outlet with a dozen plugs. You have constant and ignition wires ran off the same circuit. The wires are crossed up in the harness and ocaasionally glitch when overheated. Ford should have designed it better. I found a solution which I created which is a bypass to this problem that Ford designed. First sit in the driver's seat and look to the left of your windhield. you should see a pillar or column in the corner of the vehicle. It's in between the windshield and the driver door. Get a flat head screwdriver and remover the column in the corner. you should see a green harness. Disconnect harness and turn your key forward to make sure your windows work. If they do, good, if not check your fuse. The problem is in the top harness. This is where the short or overload is located. Remove your top console or overhead domelamp fixture in the front of the vehicle. Unhook it completely and remove the center panel where your radio is located. On the back of the radio you should see the radio harness and the wires should be labeled. Unhook the negative battery cable and splice into the "ignition switch wire" on the back of the radio. If not sure you can look it up online "Ford explorer radio wiring diagram." Get a 16 gauge wire or regular speaker wire and twist it to the igntion wire. Secure the bond with duct tape or wire caps so they don't come aloose or touch metal. run the wire to fuse number 28 which should be "radio start". strip a piece of wire on the opposite end that's not connected. The one that's going to fuse 28. Pull fuse 28 out and stick the wire into the outlet where the fuse goes. You will need a test light for this to determine which side is the hot side. Stick the wire into the hot side of the fuse outlet. put fuse back in on top of the wire. The fuse should stuff the wire down into the outlet when inserting it. Hook up the battery cable and twist forward, the radio should come on. If not check fuses or connections. The bottom green harness is where power is ditrubuted to the rest of the electronics in the vehicle. If you look at the harness on the inside you should see prongs or metal looking teeth on the inside. The second prong from the top is what powers the dome lights. test to make sure,put a test light on the second prong with the door open. If it lights up continue to hold it with the door closed and it should go off with your rear dome lamp that should be working. at the bottom of the prongs you should see square holes. stick the test light into the square hole under the prong you tested. It should light up. Get a paper clip or cotter pin and some more speaker wire and bond the wire to the clip or cotter pin by wrapping the wire around it at the end where the loop is located. Once you done that stick the pin or clip into the square hole firmly. On the domelight fixture there is a harness that connects to it that has a black wire,a blue/black wire and two green and yellow wires. Unhook the battery cable again and cut the harness about 4-5 inches and hook the wire that's hooked into the bottom green harness to the blue/black wire on the lamp fixture. hook the black wire up to a good ground on the harness. you can use the top or bottom harness for a good ground. hook up battery cable and open the door and presto!! you should have light. If not check your bulbs and check the metal connectors that the bulbs sit in with your test light to make sure there is continuity there. If you have a sunroof or vanity lamps they can all be hooked up the same way in this bypass procedure. Get some more wire,cotter pins or paper clips and go through the prongs with your test light to hook it all up with this bypass method.
Mar 02, 2011 | 2002 Ford Explorer
Looking to put remote start and bypass module in 2007 saturn vue need wiring diagram
12 VOLT CONSTANT ORANGE (+) IGNITION SWITCH HARNESS STARTER YELLOW(+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK(+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) See NOTE *1 IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) BROWN (+) @ BCM, PIN B10, GRAY 24-PIN PLUG, See NOTE *2 POWER LOCK RED/BLACK (TYPE A) @ BCM, PIN A8, 16-PIN GRAY PLUG, See NOTE *2 POWER UNLOCK ORANGE/BLACK (TYPE A) @ BCM, PIN A7, 16-PIN GRAY PLUG, See NOTE *2 LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS DOOR TRIGGER See NOTE *3 @ BCM, PINK 24-PIN PLUG, See NOTE *2 8957_VUE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf DOMELIGHT SUPERVISION WHITE (-) @ BCM, PINK 24-PIN PLUG, PIN A1, See NOTE *2 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ BCM, PIN B2, PINK 24-PIN PLUG, See NOTE *2 TACH ANY WIRE NOT PINK or RED @ IGNITION COIL WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
Feb 27, 2010 | 2007 Saturn VUE FWD 4
HORN DIAGRAM FOR A DODGE RAM 1500 (CONNECTIONS)
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Blue (16 Gauge)
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Yellow/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue (10 Gauge)
Accessory Positive Wire Location: Ignition Switch Harness
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Aug 22, 2009 | 1998 Dodge Ram 3500 2WD
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Jul 08, 2009 | Pioneer DEH-P3000 CD Player
1996 chevy 1500
with the ignition in the "off" position get a test light and touch one wire at a time while cycling the ignition switch to the "on" position, When you see that the test light goes off when the ignition switch is in the off position then you found the hot wire, make sure you dont hook it up to the "alway hot " wire or you might drain the battery hope this helps.
Oct 18, 2008 | 1996 Chevrolet Express
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
