Question about Kenwood KDC-MP2035 CD Player
No Sirius or Sat option when pressing Source button
The unit is supposedly satellite ready, yet when I go through the menu and scroll the options I don't see a SAT or Sirius option. I am using the Kenwood KCA-SR50 translator with the Sirius SC-C1.
Once everything is connected including antennae, there must be period of time for the head unit to recognize the SAT tuner (SC-C1 in this case). When I started up the car the next day the head unit automatically tuned itself to the Sirius preview channel.
Posted on Dec 08, 2008
Sony CDX-GT320 FM / AM / XM Radio / Sirius Receiver missing sat option?
Check the connections between the head unit and the XM tuner. If the connections are good check for power and ground.
Oct 14, 2012 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
The radio says it's Satellite ready, but when I hit the search button I do not get a Satellite option. When I called Sirius/XM to switch service from one car to another, they said that I must now also...
No it is satellite ready, meaning you need to add atuner to the stereo, but you can use the stereo to control the tuner. Again, a seperate tuner will need to be bought and installed. Good Luck.
Sep 08, 2011 | Kenwood Kdc-bt645u Car CD/ MP3 Player
Hello, i have a clarion xmd3, i bought it in 2004 and have a sirrius add on sara radio reciever. im trying to resubscribe for service. i need the radio to display sat radio id#. went to clarion web site...
You can get the # right off the Sirius unit (it's on a sticker on it - SID#).
Also try going between channels 1 and 184 (IE go track/tune down) it may show up then.
If not press and hold the T button for longer than 1 second. Then use the track up/down buttons to scroll through the menu. There should be a screen that will show Sirius or Sat ID or something to that effect. When you see that press the up or down button, or play pause and it should display it.
Let me know if that works.
Dec 11, 2010 | Clarion XMD3
Reset to factory settings blackberry curve
Whether you are ready to upgrade your blackberry, give it to someone else or throw it out all together, you should make sure that any personal data has been removed first. Here's an easy way to ensure that you are not throwing out, giving away, or selling a phone with your data still on it.
  • 1
    From your blackberry, scroll down to the options icon. (This is the icon shaped like a wrench) Push in the trackball or the scroll wheel to select this.
  • 2
    Once you are in the options menu, scroll down to the security option and press in the trackball or scroll wheel to enter into the security options menu.
  • 3
    Once in the security options menu, locate the general settings option and press in the trackball or scroll wheel to enter the general settings menu.
  • 4
    Great! Now you should be in the General Settings menu. At this point you can press the menu button on the blackberry. Its the button next to the green phone button. Once you press the menu button on the blackberry, you will see a menu come up. scroll to the "Wipe Handheld" option and press in the trackbacll or scroll wheel to confirm your selection. There will also be an option to remove all 3rd party applications. Check this option to remove those as well.
  • Oct 02, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
    Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
    you have to turn the AUX input on through the function menu which can be accessed by following these steps
    1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
    2. depending on the model that you have, you will have to press and hold the
    (volume button or the audio button), until a menu is displayed.
    3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
    4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
    5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
    hope this helps
    Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
    No Sirius function available.
    I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
    May 29, 2009 | Clarion XMD3
    Can't select satellite option when pressing source button.
    The Sirius Tuner is separate from the AM/FM/CD, check the plugs between the two. If all is snug, pull the SIRIUS tuner and go to a JVC dealer that would have any deck w/sirius as an option and plug it in. If it sees it, it's more than likely a problem with your deck. My guess is it's a bad SIRIUS tuner. There have been LOTS!!! Good news is there easy to replace if bad, and there cheap! $45.00 from Crutchfield rebuilt.
    May 22, 2009 | JVC KD-HDR30 CD Player
    How to hook up the sirius stratus 5 radio in my 2008 rav4?
    I have sirius installed in my 2008 RAV4 JBL system.
    There is an adapter made by VAIS technologies http://www.vaistech.com/ that is called a soundlink. It comes with instructions for the connection. The Sirius radio is hidden in this installation, and is controlled by your JBL system. The antenna runs up the side of the windshield (hidden behind the plastic moulding) and mounts to the top right corner of the roof.
    HOWEVER- you will not have the full funcionality of the Stratus 5 radio- which has more funtionality that the JBL system can control. Also, the Scrolling feature on the Stratus 5 screen does not work on the JBL display. . . you get the first 15 or so characters, with no scrolling.
    I love having an integrated satelite radio in my car, but I do miss the better screen, and the pause feature I had on my sportster (in my old car). Good Luck.
    Dec 25, 2008 | 2008 Toyota RAV4
    Trying to add more audio equipment to my Pioneer Nav stereo
    The Avic N2 is only XM ready not Sirius ready like the N3, which is SAT ready(both XM and Sirius). If you must have your Sirius the only option left for you is use the rear input on the hide away unit but you won't have it on the touchscreen. There is one more expensive option by have your N2 hardware upgrade to N3, some Ebayer have that service offer for about $275. It's done by replace a surface mounted chip with 70 plus leads. That would take some expert de-solder and solder skill with a solder torch or
    a tech's heat gun. I can do it but I don't know which chip it is. I have an immaculate N3 for sale on Ebay. Maybe you could sell your N2 and buy an N3. I usually get about $550-$650 for an N2 depend on the condition. Hope that I did some help. You can call me at 801-414-4566, I would do anything I can. Goodluck.
    Feb 15, 2008 | Pioneer AVIC-N2 Car DVD Player
    Kenwood KDC-MP2035 CD Player Logo
    200 people viewed this question
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
