Question about E-Machines T3882 PC Desktop
Usb i keep loosing my usb 2 drivers none of my usb ports seem to be working I've tried going into device manager and it says everything is working properly on usb ports. but when i plug something into a usb it says usb device not recognized go to device manager and run an updated driver and it says there is no newer version than the one i am using
  • Billy McMinn Dec 13, 2007
    My usb ports does not recognize my flashdrive or any flashdrive. I can connect my flashdrive to another computer and it works. What steps can be taken in solving this problem.
    President:
  • 2,961 Answers
Check ports are operating correctly, go to Control panel>performance & maintanace>admin tools>services. Look dow list for 'plug and play', make sure this is set at automatic, the furthur down list 'Universal plug & Play' and ensure this is set at Manual. if all is ok then it may be a usb power issue if you ave lots of hungry usb peripherals, try disconnecting some and try your problem periheral in a different usb port.
Posted on Feb 17, 2007
  • xmiss Jan 07, 2012
    Tried this... Still not working... T3882 is not recognizing hp1315 printer... Help!
Install my printer, have a message about USB port MALFUNCTION in my printer BROTHER DCP7020 laser
Hello, Jorge.
It would help to know "exactly" what the error message states, such as "The USB Device Not Recognized" or something like that. Here are a couple of things to try in order to narrow down the problem source:
1. Try a different USB connection on the computer. If that one works, the problem is probably that other connection port.
2. If none of the ports work with the printer, try a different USB-powered device, such as a cell phone and charging cable. If it works, the problem lies with the printer/computer connection (more likely the printer).
3. If none of the USB ports work, the problem might be your USB port itself. Go to "Device Manager" (in Control Panel), then look for "Universal Serial Bus controllers." Check to see if any have a disabled symbol. Check under "Properties" that device status is: "This device is working properly." If not, try updating the drivers (under the "Driver" tab).
Jan 08, 2017 | Brother DCP-7020 All-In-One Laser Printer
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
Hi, I try to plug my MP3 into one of my USB ports. Doesn't recognize it. 'Removable Disk (H:)' comes up in 'My Computer', but soon disappears.
There is a problem with your USB port
you should try getting them fixed which is a tough job, but you can try plugging your removable media into another USB port like USB ports in backside of the cabinet.
If you don't find any problem with your USB device then you must have been having problem with your Removable Media (Mp3)
If your MP3 Player is under warranty period then you can look for its repair (can be done if its out of warranty too, but it will charge you extra)
Solutions To work around the above issues, one of the below solutions could prove helpful:usb-device-not-recognized.jpg
  • Unsecure or Loose Connection
    Unplug the presently connected USB device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a USB device.
  • Scan for Hardware Changes in Device Manager
    Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the USB device.
  • USB Power Management
    Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps; Click Start, and then click Run. Type devmgmt.msc in the popup box, and then click Ok. Expand the Universal Serial Bus Controllers' node, and then follow these steps for each USB Root Hub that is listed. 1. Right-click the USB Root Hub and then click Properties.
    2. Click the Power Management tab.
    3. Click to clear the Allow the computer to turn off this device to save power check box, and then click Ok.
    Note: If you perform the following procedure on a laptop computer, you may reduce the battery life.
Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert
Aug 11, 2011 | HP Pavilion Slimline s3407c Desktop,...
I have 4 usb poorts on my barebone. two of them
If these are case front/top or other panel ports, verify that the ports are connected correctly.
if ports are configured correctly, remove all usb drivers via device manager. then reinstall them. if the problem still occurs you either have corrupt usb drivers (probably not since 2 ports work) or the USB ports were damaged in installation or because of usage.
sometimes the ports will not clear their settings, try the object you are plugging into the 2 non-workign ones to another port hen try something you never plugged into the 2 non-working. if you still get an error, its a driver or damage issues
Feb 11, 2010 | ASUS P1-P5945G Motherboard
XP crashed on my Dell latitude D600 laptop. I reloaded XP and all drivers. Everything works except it does not detect any device when plugged into the usb ports. They do light up. Utlities suggest that the...
I cant figure out a solution exactly as you have already tried things people have told you previously. but as far as i know dell should solve your problem for free instead of telling you to fix it. did you try contacting them and are you in your warrenty period?
Aug 03, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Missing USB controller driver
When posting driver issues, you need to specify what kind of equip you are dealing with, not just the issue. Most liekly you need to go to the manufacturs website of your motherboard or laptop and find vista drivers for it.
Jul 29, 2008 | Acer Aspire 5100 Notebook
E-Machines T3882 PC Desktop Logo
138 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
