Question about Linksys Wireless-G WRT54G Router
I am setting up a PC with wireless capability, I am prompted for mu "network key" ???? What is this key?
  • Linksys Master
  • 4,338 Answers
You need to go to Main PC( one that is wired to the router). Open a browser and type in 192.168.1.1 When the login box opens, log into to this WRT54G , using the default password, admin, leave the username blank.On the setup page you have wireless tab under which you have wireless security. Click on Wireless Security here, if you have selected Security Mode as WEP then key1 is your WEP KEY.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 07, 2008
  • 337 Answers
The router has WEP or WPA, it locked with a security code, if you know the owner you could ask for it
Enable wireless capability
Certain models of Acer desktop computers are designed with wireless capabilities.
These capabilities can be added to an Acer desktop system that does not connect wirelessly with either an internal or external wireless card, depending on the computer's configuration.
When the wireless connection is not working properly, you can troubleshoot the issue yourself.
The troubleshooting process eliminates the problems that may be preventing the Acer desktop computer from connecting wirelessly.
Check to see if any other computers at the same location are able to connect wirelessly.
The issue may reside with the wireless router or access point.
Power cycling the router or access point may resolve this issue.
Verify that the wireless adapter is enabled.
Click the "Start" button, then "Control Panel."
Click "Network and Sharing Center," then "Change Adapter Settings."
If the wireless adapter is disabled, right-click on it and select "Enable."
Connect to the proper wireless network.
The Acer may be attempting to the connect to the wrong wireless network, or it may have lost its connection to the correct network.
Click the wireless network icon in the task bar.
Click the proper wireless network, then click "Connect."
Enter the network password (or WEP key) if prompted.
May 26, 2013 | Acer Aspire Computers & Internet
How to turn on wireless capability
Install the wireless card driver if it is not installed.
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 20, 2013 | LG Computers & Internet
Wireless capability turned off
Wireless capability will turn on after Press Function Key (fn - Red) + F2. if wireless adapter is turn off you can turn it on at Network and searing center on control panel > Change adapter setting > Double click on disabled wireless adapter.
Hope it Works. Enjoy.
Nov 03, 2012 | Dell Inspiron 1545 Notebook
How to turn on Wireless capabilities on an Aspire 3000
  • Turn the Wi-Fi switch on the outside of the laptop to the "On" position if it is not already on.
  • 2
    Select "Control Panel" from the "Windows Start" menu. Select the "Network Connections" control panel.
  • 3
    Right-click the "Wireless Network Connection" beneath the "LAN or High-Speed Internet" header. Select "View Available Wireless Networks" from the context menu.
  • 4
    Select your wireless network and click "Connect." If you have a password set up, enter it when prompted and click "Connect" again. If no password is set up, a window will alert you that the network is not secured---click "Connect Anyway" to connect to the network.
  • Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
    Oct 16, 2010 | Acer Aspire 3000 Notebook
    Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
    HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
    However since this printer has Ethernet Port, you can still make this printer wireless.
    You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
    Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
    How this works,
    With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
    Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
    Connect another computer to wireless router instructions say go to site www.linksysfix.com/ela
    on any standard UNSECURED router, all you should have to do is click connect under "Network connections" in Control Panel. However, if the wireless router you would like to connect to is SECURED (password protected), you will just need to type in the password required in the connections when prompted.
    This is assuming the other computer you are trying to add is wireless capable.
    Jul 24, 2009 | Linksys WMP300N Pre-802.11n Wireless...
    Wireless connection to a 2 wire
    you need to access the router's setup page to get the network key. enter http://192.168.1.254 on the address bar of your web browser. you will be prompted with the router's screen. look for the wireless settings and locate the wireless security and it will prompt you for the network key.
    hope this'll help you
    ciao
    Nov 09, 2008 | 2wire HomePortal® 1800HW Router...
    Amlio li 2727 notebook adding to wireless network
    find out first if your comp is wireless capable, then if it is, see if your wireless network is locked. for what ever wireless you are using you can go to the website and see if there is a way to get your passkey info. once you have that info then you should be able to add you comp. however if your comp isnt wireless capable then you will net a wireless card, pref. the same name as your wireless router.
    Aug 25, 2008 | Computers & Internet
    I bought an Acer notebook (Aspire 9920) back in December. My ISP manual says that the 'Wireless Network Key' should be on the base of the notebook on a coloured label. This doesn't appear to be the case....
    A wireless network key is used to join to a wireless network. Wireless networks are created by routers and/or access points. In order to obtain the key so you can log onto the network, you must have access to the router's settings or be given the key by someone who can access the router. To access the router, you type in it's IP address into your internet browser. If it is password protected, you will need that as well. Once in the router settings, you can set many configuration options, including the wireless network password or passphrase and encryption type.
    Again, if you are joining to a wireless network, the KEY is determined by the router, not the laptop. This is how multiple wireless devices are allowed onto the same network: they all use the same key.
    Mar 28, 2008 | Computers & Internet
    Linksys Wireless-G WRT54G Router Logo
    74 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
