Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
LAPTOP LOSS CONNECTIVITY TO WIRELESS g ROUTER
HAVE TRIED TO LET ISP SOLVE BUT NO LUCK...HELP
  • Keith Deininger
    Keith Deininger May 11, 2010
    I need to know what type of wireless router you are using, type of wireless NIC in your desktop or laptop and what OS you are using, either Windows XP, Vista, Mac OSX, or Linux.
    Are you using a DSL router (through telephone company) or Cable Modem (Such as Comcast or Charter)?
    Please provide some further information so that I can assist you further.
    Cheers,
    Keith
  • 827 Answers
Try unplugging the router's power for 20 seconds, then rebooting the computer. worked for me.
also if you are using a linux distro, you have to maybe click on the internet icon and click the applicable connection for it to connect to the network. hope this helps.
chris
Posted on Dec 12, 2008
HP Officejet Pro L7650
The problem could be your web browser and its settings. You can try using another computer, or another browser. If you are using Internet Explorer, dry downloadingFirefox and accessing the router again. Hope this helps.Can you tell me which Internet Service Provider having you use. If your physical connectivity is pour or every minute or while reconnect your physical connectivity then your router also reconnect your ISP so router ask you password conformation for that.
If you using DSL connection then you do first that check your telephone wire physical connectivity and also if you have multimeter than check telephone wire voltage if is not stable than your telephone connectivitiy is pour so called telephone mechenic for that.
if everything is ok than ask your router company.
Dec 05, 2011 | Linksys Wireless-G Broadband Router
When I switch my laptop on and click onto Internet Explorer it then takes 20 mins before I can open my emails my home page is Sky and I am on Wireless
Without a good technician on site to diagnose the problem, there could be a 1000 things wrong, First verify all cables and power sources, laptop connectivity as well (test it on an other wireless network, friend, office, etc..), shut down all devices (router, modem, etc.) than power up all devices, if still not working, than try plugging your laptop directly to the router with an ethernet cable in one of the ethernt ports of the router, this will tell you if there is a problem with the wireless or not, if you have the same problem connected with a wire, than you can verify your (Internet Service Provider) ISP's connectivity by plugging the laptop directly to the ISP's modem with the ethernet cable, (MAKE SURE YOUR ANTI-VIRUS IS UP TO DATE) as you won't have any firewall to protect you, if the problem still persist than call your ISP for support... if the speed is OK at that point, than you should reset the router to factory default and re-configure the router, if you still have a slow connectivity after that than you should replace the router, (assuming all cables ant power sources are good, the laptop's configuration as well)... now you know why a good technician is 65$/hour
Cheers!
Jul 07, 2011 | Computers & Internet
My laptop keeps telling me that it has limited connectivity to my telstra wireless modem and will not go on to the internet, please help. its very frustrating!!
this is because your internet link from the router to your ISP is failing to connect.
Thus yo are limited to the router connection.
Mar 07, 2010 | Dynalink (V1456VQH) Modem
Loss of wireless connection
Is your laptop able to connect to other networks? If so, your router maybe at fault. Reset the router, if it still doesn't work, you may need a new router. If your laptop has issues connecting to other networks, the wifi radio in your laptop may need to be replaced.
Jan 06, 2010 | Zoom X6 (5590) DSL Modem (55900003)
My internet keeps dro, i have installed filters ,
There is one case where everything is fine but still connection drops too often.---
This happens when the network type of your laptop is "public" as ublic networks are less secure, routers usually drop connections after sme time. Change the network type to "private". This should solve your problem. There is one more setting in your router where is says something like "automatically login when disconnected". Selecting this option allows automatically login to ISP when connection is dropped from ISP temporarily.
If network connectivity itself is the problem then you can debug followingly.
Step-1:
If ISP company says everything is fine from their side, then you need to check your router. To confirm this first connect the wall outlet of ISP to your laptop and check network connectivity. If there is problem, then ISP has to fix it.
Step-2:
If connection works fine then ISP is fine and you need to check your router settings. Now check network connectivity by connecting the laptop to the router through a ethernet wire. If the network does not work then your router hardware could be wrong and may need servicing or replacement. If this works fine then go to step-3.
Step-3:
Try resetting your router by using a paperclip. Usually the reset button can be found at the backside of your router. This will reset all the settings and there by making as good as a fresh one. Try to access internet from a place close to router where router signal is strong.
Change authentication and other network settings of your router to connect to ISP. Now network should work fine. Ensure that you set router password to avoid unauthorized access to your router by others.
Nov 08, 2009 | D-Link Computers & Internet
I have a linksys wireless router that someone just gave me but i dont have the installation cd. Is there any other way to install it? I have tried hooking it up but i get nothing.
No need ti install cd for router
steps
1,connect router to isp provider connection
2,connect network cable from the laptop/pc to router
type ip address of the router on the computer browser
eg:192.168.1.1
username:admin
password: admin or admin12
configure the router by the help of isp provider
Nov 01, 2009 | Linksys WRT160N Wireless Router
Limited or no connectivity
It is dhcp server issue.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to advanced and enable dhcp .
Then save settings and then restart .
Also you can set ip addrese manualy but make sure it is in range with router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Limited connectivity - wireless
Verify if your wireless option on the router is enabled.
Also when you setting the wireless on the router, be sure that channel is not on automatic. Specify a channel number. After that try to connect again to wireless
Aug 05, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Connecting to the wireless router
You would have to consult your Motorola wireless router support
Have you tried this link ?
http://broadband.motorola.com/consumers/support/default.asp?supportSection=CableModems
Jan 18, 2009 | Arris Wireless G Broadband Router (wr850g)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
29 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
