Question about Conair Nm6s Body Benefits Vibrating Neck Massager Withheat/Sound
Need a new power dial/switch. Where can I get one?
  • 66 Answers
The power switch is not replaceable as a seperate part. The entire unit needs to be replaced
Posted on May 05, 2009
Hi, we just got a new woods 59017 timer, and the dial turned until it turned off, at the point that we indicated, but after it turned off, the dial remained stuck in its place and will not turn any...
You have new 59017 single-pole in-wall 24-hour timer with tripper pins located on dial.
Timer is heavy duty and will handle up to 2500Watts 1 HP, including anything typically controlled by 15-20Amp light switch: incandescent, florescent, CFL, motor, pump, AC, whole house fan, etc.
http://waterheatertimer.org/images/Woods-59017-mechanical-timer-300.jpg
When timer is wired correctly, timer dial rotates no matter which position slide switch is set to.
Your dial rotated correctly and turned lamp ON, and rotated correctly until lamp turned OFF, and then stopped rotating.
This implies loss of power.
Check circuit breaker.
Check for loose wire on timer installation.
If wiring checks out, then timer is suspect. Replace different switch with suspect timer, and see if timer works on different Load.
http://waterheatertimer.org/images/GE-15070-wiring-1-500.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
Aug 08, 2011 | Woods Mechanical Inwall Timer 59017
Hi, The dial on our Dualit toaster gets stuck on
The timer can be rplaced by any good handyman. You can get a new one on ebay there are two types make sure you get the right one. Replace it before someone forgets to shut it off and the toaster smokes up the kitchen. Its a common problem with the dualits but the switch is not cheap and you can only get it from England. The good news is the replacement seems to be better made than the original
Jan 09, 2011 | Dualit 20084 2Slice Toaster
Power comes from light to switch.want to wire in another switch (same box) to operate another separate light
OK .. for this to work, you would need to confirm that the power cable is also in this wall box. So in that wall box you need the existing power cable, the existing light cable, and a new light cable. All the cables being 2 wire with ground. Then just jumper the black power wire top the new switch, and connect the new light , black wire to the switch, the whites will all be together ..
If there is only one cable in this wall box , then the power is run to some other box and you need a neutral for the new light. That may mean rewiring the power tyop get it to the wall box, or rewing the new light to get power from it.
Please Vote !!
Mar 22, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
Oven heats up when power to cooker is turned on ( dial is at off position)
It sounds like the oven thermostat/regulator is faulty, or the dial is not turning the switch off properly, this could be caused by the dial being cracked or broken.
Pull the dial off, and try the switch with a pair of grips or pliers to make sure it is completely turned off.
If it is, then the you need to replace the switch or thermostat as the case may be.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 08, 2010 | Hotpoint Ovens
Faulty dial switch?
Go to a good electrical component store like The Source and buy a can of Switch Contact Cleaner and spray it into the dial making sure you remove the batteries first. Then give the dial half a dozen turns each way. Leave it for 30 minutes and then re-install the battery.
Sometimes you need to move your grip on the camera, so your fingers are not near the dial when shooting.
Nov 28, 2009 | Kodak EasyShare DX4530 Digital Camera
My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Feb 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Dec 30, 2007 | Uniden Cordless Phone
Won't do anything
no, you need a lid switch. when the switch fails it wont do anything but fill. replace switch to fix problem
Nov 18, 2007 | Whirlpool LTE6234D Top Load Stacked...
Switches off whenever I try put it into photo mode
This is the lens motor not responding Nothing for you to do there any repair is likely to be expensive Contact Panasonic for further advise a New camera perhaps
Aug 02, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Conair Nm6s Body Benefits Vibrating Neck Massager Withheat/Sound Logo
145 people viewed this question
Top Conair Luggage & Travel Experts
ray gallant
Tom Chichester
Dave braun
Dave braun
Are you a Conair Luggage and Travel Expert? Answer questions, earn points and help others
