Question about Dewalt DC011 AM/FM Radio
Dw911 radio charger
I have checked both fuses, and they are good. The unit won't charge a battery or play the radio, if i charge a battery and put in the radio,
The radio will play. I have 120 volt to the circuit board, but the fuse on that board show 12 volt.
  • 2 more comments
  • fuelpipeline Dec 07, 2008
    is there any drawing out there for this unit dw911
  • Anonymous Dec 30, 2008
    i have same problem is there a fix ? radio will not work or charge battery when plugged in . if i put a freshly charged battery it will play. also when you plug it in , the charge lite comes on for a second then goes out
  • Anonymous Mar 18, 2009
    i have exactl same problem as above
  • bobbob30144 Apr 27, 2009
    Radio only works with battery in charger.Battery will not charge
  • 23 Answers
DW911 charge light flashes when no there is no battery in radio
Sometimes when a battery is too low it takes a while for it to initialize in a charger and begin to charge. Clean the battery contacts with a pencil eraser and put it back on the charger. Leave it on the charger despite the blinking light. Leave it on the charger for several hours and see if the flash stops and it becomes a constant light indicating normal charging. If this does not work, you may have a short in the battery or in the charger itself. Try another known good battery in the charger and see if you have the same problem. If so the charger has an issue.
Best regards.
May 22, 2013 | Radio Communications
Dewalt radio dw911 will play on mains but nothing with battery only
If you pull of the back cover you will find two small fuses near power supply, one of these allows power from battery pack, check with voltmeter for open circuit, I take it that it is not just one battery it does this with.
Nov 27, 2007 | Audio Players & Recorders
Works off battery or A/C, but will not charge.
The charger unit is fried It is expensive to fix and not worth it
Jul 26, 2012 | Dewalt DC011 AM/FM Radio
My Cobra micro talk two-way radios have lithium batteries. They will not charge in the charger, the light won't come on. If I take the batteries out and put them in the charger alone the light lights...
Check your battery contacts to see if they have a film of dirt or debris. If so, clean them with a pencil eraser. Check to see they are making good alignment with the contacts in the charger. If these suggestions do not solve your issue, you may have a bad solder on a battery contact in the radio. (Be certain the radio is shut off when charging.)
Best regards.
Sep 24, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I have a Dewalt radio (Dw911) that will only play off the battery, not the power cord. I have checked both fuses and found both to be good. It sounds as if this is a common issue but I have found no...
Mine had the same problem .Try swapping the fuses. Although the fuse looked good mine was bad. Easy fix I hope. Going to auto parts store for new ones.
Oct 09, 2010 | Dewalt Audio Players & Recorders
My dewalt dw911 radio/charger works on either mains or battery but wont charge a battery and blows an internal fuse when both are used together
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Oct 24, 2009 | Dewalt DC011 AM/FM Radio
Is not charging batteries but it will play off the batteries
Check iside radio, there is a metal box which is your charger unit. You need to undo the 2 phillip screws on the charger housing to gain access to the fuse inside which is a 2 amp.
Oct 02, 2009 | Dewalt DC011 AM/FM Radio
Sorry but does the dw911 xe type 1 radio charge the battery
Yes, the DeWalt radio will recharge the batteries, from the 12 Volt to 18 Volt versions. However, even with the radio plugged into an AC outlet, you have to either have the radio turned on, or have the unit in the AUX setting, in order for the batteries to get charged.
It typicaly takes about an hour +/- to fully charge a discharged battery. I normally don't put batteries directly into a charger right after they become discharged from being used in a tool, since they are still warm from use and charging them will generate more heat in the recharging
process.
Heat is the enemy of rechargeable batteries, so to get the longest working life out of your batteries, I'd let them cool down first, before recharging them, unless you absolutely need to use them right away, then go ahead and recharge them. If you can delay recharging them until they've cooled down, you'll get a more fuller recharge out of them.
Hope you find this Very Helpful and best regards!
Sep 30, 2009 | Dewalt Drills
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
1,000 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
