Question about Mitsubishi WS-55511 55" Rear Projection Television
PROJECTION TV COLORS DISTORTED
Hi, Question on Mitsubishi projection tv. mod ws55511.
Colos seem to look somewhat distorted. Are there any adjustments that can be done by a layman like on old tube sets tobring things back in focus? Thanks in advance. Bob
  • botak Dec 08, 2008
    Thank you very much for your help.
    Bob
  • 505 Answers
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Posted on Dec 07, 2008
I replaced the Convergence chip on my WS55511, and now the colors align properly, so there isn't a convergence problem. But the picture still isn't right. The colors shift towards red in the...
You have your input R G B / component wires hooked up incorrectly. The tv is detecting that and letting you know. disconnect and redo observe the color matching.
Oct 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi ws55511 hd is projecting a distorted view on screen
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Double image on picture model # ws55511
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jun 24, 2009 | Mitsubishi WS-55511 55" Rear Projection...
MY TV COLOS GO AWAY GOES DARK CLOUDY KIND OF GRAYISH
Check your color wheel sounds like that is going bad. 90% of the time the color wheel is the culprit in this cause. You will need to remove the back panel to get the to color wheel. You will see 7 different plastic adjustments. You can also order this part online at mitsubishis website
Apr 10, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Green Shade on tv screen
This is a typical example of a convergence amplifier failing (any brand would be the same).
More than likely there are 3 amps and they should all be replaced together. Parts shouldn't be too
expensive but I would expect approx $100 US in North America and about £100 UK. Bear in mind thats for the repair not any transportation costs to/from the repair centre.
Nov 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Mitsubishi WS55511 Convergenc
REPLACE THE CONVERGENCE IC (OR IC'S). A FUN JOB I CHARGE ABOUT 200 FOR.
Jun 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Color problem with DLP TV
If pic. is distorted when warm :. Suspect the FMT PCB part # 930B924002
Sep 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
