Question about SanDisk Sansa e260 MP3 Player
No spaces in text anymore
Okay, it's a long story how it got to this, but I had to fix other problems with the player, (by resetting it and updating the firmware) and after I finished re-transferring all 800 songs individually, I turn on the player, and there's no space between separate words anywhere. For example, instead of "The Goo Goo Dolls", it says, "TheGooGooDolls". This is really frustrating, and I don't want to take hours to re-transfer every song again. Can anyone help?
  • 8,596 Answers
Re: No spaces in text anymore
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 24, 2008
0 characters
3 Points
I have a problem with my SanDisk Sansa m230 MP3 Player. It has 512 MB of free space to begin with. I have used up 342.6 MB of space (47 songs),but now it says that I have used up all the space. I can't...
You Can Download Free MP3 From Youtube By This Site :
If you didn't found Your Favorite Music In Youtube Try These Sites : or
Accepte my greetings
Apr 05, 2010 | SanDisk Sansa m230 MP3 Player
I,ve deleted films, but it has,nt given me anymore free space on the harddrive
Have You Tried updating the ACR Library?
Settings>System> Update ARC Library
Sep 02, 2009 | Archos 605 WiFi Digital Media Player
My sanza isn't reading any songs that i put on there anymore. I tried to delete the songs but it didn't work. so i tried to format it so i can free up all the space but it said format cannot be completed....
Okay are you talking about the internal memory or the SD disc?
If it is internal memory you could try a reset = Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
If it is the SD did you upgrade your Sanza to support Slot Radio? Slot radio does not use a file structure supported by Windows computer system.
Jul 13, 2009 | SanDisk Sansa e250 MP3 Player
Profiling requires 4mb free space; reformat required
1. Disconnect the player.
2. Download the new driver from
3. Install the software on your computer, then run it.
4. Reset your player by either pressing the reset button or removing the AA-battery from the player.
5. While holding down the "Play" key on your player, connect it to the PC via the USB cable. Release the "Play" key when you see the progress bar moving and "initializing" text. If you cannot see the "initializing" text, please disconnect your player and try again.
6. Click the "Start" button to upgrade your player
Jun 02, 2009 | RCA JET S2002 MP3 Player
Firmware upgrade not working
Are you absolutely sure that you loaded the firmware for your correct model #? Try downloading the auto-updater software and see if it will take the upgrade on the next go around.
If not, that player is fried - update during firmware upgrade is no good. Call rCA to see if you are still in warranty.
Usually the "50MB of space needed to operate error" is easy to fix, but also most other manufacturers have a specific FAQ on their website that tells you how to fix it. RCA did not have anything like that for this model. also, most other manf. have a recovery tool of some kind - absent on this model.
Jun 28, 2008 | RCA OPAL M4001 MP3 Player
Ipod 1st gen dont connect or charge anymore on laptop
the internal battery is going dead this may be the reason why is not charging. The computer is not recognize the i pot is may be you need to update your firm ware. Hop this will help you solve the problem
Apr 18, 2008 | Apple iPod nano
Syncing Problems
sounds like your hard drive is shot, these players are not made to handle much, may not be an expensive fix
Mar 22, 2008 | iRiver H10 MP3 Player
Sansa 4 GB mp4 player
Go back to were you bought it and make up a story that the bat. does not work and they will ecchenge it for a new one
Trust me it works i'v tryd
PS:The story has to be good
Dec 04, 2007 | SanDisk Sansa e250 MP3 Player
Pc not recognizing zen
Does the firmware update recognize it?
Jun 14, 2007 | Creative Labs ZEN Vision:M Digital Media...
Hi. Seems like it's time to update your player's firmware. Mine got dislexic too and this is what I was told to do by the Sandisk tech support guys: If you have the E200 "Rhapsody" player (like E260R for example), use this link from the SanDisk website to update your Firmware: If you have the "Standard" E200 player, use this link: It fixed mine. I'm hopin it'll fix yours as well. :)
May 06, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
35 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
