Question about Kenmore 24872 Top Load Washer
Washer won't drain or spin
Top Loading Kenmore. Washer will fill and agitate, will also begin rinse cycle. When it comes time to drain and spin, it just sits there. Any ideas would be welcome.
    President:
  • 1,294 Answers
Did u clean out your outlet filter. If u did..... Go to 'troubleshooting' above, click on page 2, look for 'replacing lid switch' Generic Problem. Catriver is pretty good.
Posted on May 02, 2007
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    I have a Kenmore top loading washer model #110 and won't agitate
    First, see the Sears parts site for your washer.
    http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
    Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
    I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
    Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
    These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
    Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
    Nov 14, 2009 | Kenmore 22422 Top Load Washer
    22432 won't spin or drain
    CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
    Aug 30, 2009 | Kenmore 22422 Top Load Washer
    GEwdsr2080d top loading washer will not drain or spin
    Yes, a magnetic lid switch and it is defective.
    Replace it.
    Mar 12, 2009 | GE Washing Machines
    Machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 24872 Top Load Washer Logo
    161 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
