-   no longer has the ozone smell have replaced plates with new ones and that did not fix the problem-   Guest
Best Solution
posted on Aug 08, 2005
Bray - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Some Air Purifiers have an independently controlled ionizer, which, when turned on, releases negative ions into outgoing filtered air. Ions are tiny particles that carry a positive or negative charge. These ions exist naturally around us, in the air, water and ground. Both positive and negative ions are colorless, odorless and completely harmless. Negative ions help the air purification process by attaching themselves to very small airborne particles in the room. These particles take on a negative charge and may join with positively charged particles such as dust, pollen, smoke and pet dander to form larger particles that are then more readily captured by the filter system, or may be attracted to positively charged surfaces throughout the home, like walls or floors. This may occur more frequently when the filter is nearing the end of its functional life expectancy and is able to capture less of the charged particles. You may also note after extended use, that dust may have collected around the grills or front panel. This is from the ionization affect caused by the negative ions exiting from the air outlet. This is additional evidence of the air cleaning effectiveness of negative ions. The dust can be easily removed with a clean, damp cloth or soft brush. Finally, using your ionizer may result in an occasional popping or cracking sound. This is a normal sound, generally caused by particles of dust that are interrupting the flow of ions, causing a small build-up of ions that, when discharged, cause the popping or cracking sound. NOTE: It is important to replace the HEPA filter at the recommended intervals. Using the ionizer in conjunction with dirty filters may result in dirty particles exiting the air purifier and being attracted to walls, carpets, furniture or other household objects. These dirty particles may prove very difficult to remove. Homes with excessive amounts of pet dander, dust, or smoke may decrease the life expectancy of the HEPA filtration system. You may want to run the Ionizer less often and check the condition of the HEPA filter(s) more frequently. ?
Neither negative nor positive IONS purify air. Humans and animals both do better physically and mentally in a negative ion charged environment, however. Our SUN AIRE purifiers not only safely purify your air, but will replenish the negative ion balance in your indoor air which is scrubbed out by your heating and/or air conditioning. Ionizers are just a different method of AIR FILTERING. Much like two magnets- one being negative and the other being positive, ionizers produce negative ions which are attracted to a postively charged plate. You then have some of your live airborne contaminates stuck to a charged plate. You still have not killed anything airborne; i.e bacteria & viruses; mold spores; etc. You have simply FILTERED some onto a charged plate.
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the...
(More)
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the local rainsoft dealer! The parts are: LAHV91, Rainsoft PN: 65048 and the LAHN90L PN: 65501. Can you tell me where to buy them?
i have the fresh aire model just replaced rci cell cleaned filter and cleaned the ozone plate. the...
(More)
I HAVE THE FRESH AIRE MODEL JUST REPLACED rci CELL CLEANED FILTER AND CLEANED THE OZONE PLATE. THE FAN KEEPS TURNING ON AND OFF?? STARTS RIGHT BACK UP ON ITS OWN AND THROWS NO EROR MESSAGES??
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I...
(More)
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I get the top out?
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It...
(More)
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It seems to be getting power bc the lights turn on like normal but thats all that seems to get power. Is there a way to check if the motor is working without replacing it? thank you
