Question about Haier ESD200 Built-in Dishwasher
Burnt out heating element
Hi Guys, Well I have an Haier Protable dishwasher HDP18PA and the heating element is no longer alive. Its about 2yrs old and I have already had it worked on once and so far other than the heat it works fine. Can I order this and do it myself. Yes, I am fairly handy :) Haier is really a hasssle to deal with, takes a loonng time to get any help. If you could help in anyway it would be very much apprecated! Thanks, Karen
  • 334 Answers
Yes, you may even be able to pick the part up as an in-stock item at your local appliance parts supply house. The place the local appliance repair pro's go to get parts.
Replacing the actual element is fairly easy. Its typically a few screws and two wires the simply disconnect via stakon connectors or a molex plug.
The "hard part" is actually getting to the elements mounts and wires. with most units you have to remove a panel or two, to get to the element housing and access the element.
The main thing? Make sure power is disconnected, and pay close attention to how everything comes apart and which direction each piece was originally installed.
It may help to get paper and draw yourself a diagram of the disassembly process.
Posted on Dec 07, 2008
Need operators manual for a haier dishwasher hdp18pa
www.specsserver.com/CACHE/FRWDAJEQUXIO.PDF Full downloadable manuel
Sep 24, 2011 | Haier HDP18PA Stainless Steel...
I need an operators manual for this model dish washer. I bought it used and they did not have a manual
I was just signing off for the night when I saw this. You can download your user manual free from here:
http://www.haier.com/admin/en/product/upload/HDP18PA-UM.PDF
Click the link and the manual will open in a new window, you can then print it or save it to your PC for future reference by clicking "File" in the top left corner of the browser window and then clicking on "Print" or "Save As...". If you are unable to open the file, you will also need to download the latest version of Adobe Reader:
http://get.adobe.com/reader/
Regards,
BElectric
Nov 23, 2010 | Haier HDP18PA Stainless Steel...
Water is splashing back at me when I hook up the Haier HDP18PA shy?
1)If cycles not complete before opens(it will splash)
2)check any block in rinse arm.
Jan 08, 2010 | Haier HDP18PA Stainless Steel...
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
The washing detergent is not released
Hi, I have this same unit and the same thing would happen to me too. I discovered that it was my dishes that were getting in the way of the detergent door. I'm sure you're are, but make sure that all your plates/bowls, etc, are pushed far enough back that they don't interfere with the poorly placed detergent door.
Nov 10, 2008 | Haier HDP18PA Stainless Steel...
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Heating element
  • Remove the screws on the back of the unit and take off the back two panels.
  • Facing the back, there is a thermostat toward the back-middle-right... it has a brass nut that holds it in place and two wires attached to it. (my wires were pink). Check this first: check the wiring here, and if you have a multimeter, check the continuity between the two terminals. It should be closed (conducting) when cold.
  • You should see the wires for the heating coil on the left side. If you have a multimeter, check the resistance across the left and right  terminals (the middle terminal with green wires is ground). If there is no continuity, the heater is dead.
  • Finally, the only other cause would be the relay (hidden off in the right-rear corner of the unit) or the control panel.
Jan 29, 2008 | Haier HDP18PA Stainless Steel...
Haier ESD200 Built-in Dishwasher Logo
166 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
