Question about Pioneer DV-260 DVD Player
Is there any software out there to make physically perfect unrecordable dvd's useable again. I had an older recorded that ruined about 100 discs before i bought a new one. I can see on the disc a small or sometimes larger ring on the leading recording center? thanks
  • tbertnic Dec 07, 2008
    The DVD is perfect except for the fact that an initial piece of data was written onto the disc that makes it unloadable. I can see that the disc is completely empty, so I would like to try to use the disc for recording before filing them in the shredder. Thanks for any help someone might have.
    Genius:
  • 1,199 Answers
GET A SMALL PIECE OF RUBBER AND PLACE THE DVD UPSIDE DOWN SO DAMAGE IS FACING UP NOW GET A BUFFER FOR A CAR (ELECTRIC!) AND SOME NON ABRAISAVE PAST WAX FOR CARS...RUB A THIN COAT OF WAX ON THE DVD OR CD AND LET DRY NOW BUFF THE DISC WITH A FIRM PRESSURE, BUFF FOR 30 SECONDS THEN CHECK! THIS WORKS FOR ME EVERY TIME REPETE IF NESSARY
Posted on Dec 07, 2008
Problem Pioneer DVR-520H
your lens needs to be replaced.
Jan 27, 2008 | Pioneer DVR-520H DVD Recorder
Emerson EWR10D5 DVD Recorder/Player - using 16x DVD-R I get an error while recording
Sounds like a bad disc. You may also want to clean the laser lens with a cleaner disc just to be sure.
Sep 07, 2017 | Emerson Televison & Video
I have a dvdr3380 lately when i put in disc it says disc unrecord
Test the created DVD with TMPGEnc v4.0 Xpress here is the free trial link It has a read source function that will fail if the DVDR has not been authored correctly.
If this works and scans in the full DVDR then I suggested that you buy a branded DVD+R like Philips who created the format, if this still fails I think you DVDR 3380 will need a service.
LOL
Mar 15, 2009 | Philips DVDR3380/05 DVD Recorder
Have a samsung Samsung LE26A456C and a toshiba dvd recorder. Have set up telly fine, set up video to play fine but cannot record
What is it that you are trying to record? If you are trying to record a DVD you have purchased onto a DVD-R, you will almost always run into a problem because most purchased DVDs have copyright codes burned into them, making them unrecordable. Most VHS tapes have these copyright protection codes in them as wel. If you are trying to record a television show, and are unable to do so, make sure that the DVD that you are using is compatible with your burner. If your burner is set up to record only DVD-R, then you must use only the DVD-R discs. If your burner is set up to record only DVD+R, then you must use only the DVD+R discs. Some burners will record both the DVD-R and DVD+R. If you have the right discs for your burner, make sure that the discs are correctly formatted to be recorded. Also, make sure that if you are recording from a cable box or other input that you have the correct unput channel selected on the burner. If these suggestions don't work, then it could be the brand of DVD that you have purchased (i.e. Sony,Maxell,TDK,Fuji,etc.). Check your manual for acceptable brands. I hope this helps you out. Let me know if I can be of further assistance.
Sep 08, 2008 | Samsung Televison & Video
Dub VHS to DVD
I am not sure why the DVD recorder is stopping after 25 mins of recording. However, once a disk is finalized all the remaining space is unrecordable. That is why your computer is showing the disk as full. The same applies when finalizing a CD. As for the first problem, check to see what record speed you are using. XP is 1 hr, SP 2hr and so on. But stopping after 25 minutes is weird. Even if you use a quick record button, (aka OTR) the recording is usually done in 30 minute increments. Try it again. If it still is only recording for 25 minutes, you may want to contact the manufacture's customer service or tech support. Hope it helps.
Mar 23, 2008 | Zenith XBR716
Recording problem
yes cant use those rw use dvd +r memerex best ok on sale too this week best buy 1299 50 pack ok
Jan 29, 2008 | Panasonic DMR-ES10 DVD Recorder
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
TDK dvd+r home copied disc
check drive properties inorder to verify whether ur drive support +R dvd
Nov 30, 2007 | Computers & Internet
Pioneer DV-260 DVD Player Logo
50 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
