Question about Akai Televison & Video
Tv work come on , all 3 lights blinking
Started shutting off on its own then stopped coming on at all
  • 505 Answers
All 3 leds blinking is a Lamp error. Pull the lamp and see if it is blown. If so, replace. This error can also be caused by many parts of the optical block = colorwheel, balast, or DMD board. If you hear a buzz sound when it tries to fire lamp then the lamp is bad. If not listen for the spinning high pitched squeel of the colorwheel coming up. If you hear this but no buzz from the ballast, you likely have a bad ballast. If you do not hear the color wheel, you have a bad color wheel or DMD board.
Posted on Dec 07, 2008
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Heard a pop, tv went off, then doesnt come back on
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 23, 2010 | Hitachi 50VF820 Projection TV
Tv doesn't want to start
The power light blinks about 9 times and the tv wont turn on what does this mean? its a magnavox 51mp392h/17
Aug 05, 2009 | Sony Televison & Video
Turning On Problem
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 06, 2008 | Samsung HLN467W 46" Rear Projection HDTV
My dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Aug 03, 2007 | Frigidaire 18 in. FDR252RB Built-in...
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
94 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
