Question about Frigidaire FEF366 Electric Kitchen Range
Oven bake element will not turn on.
Frigidaire model # fef366dse. Element is not broken and the oven will not heat up. i have replaced element, unplug and plug back in, nothing works. Unit is only 2 years old. Thank you in advance for all the help.
  • Anonymous Mar 23, 2014
    The double element for the grill in my indesit oven 2660W needs replacing. How do i go about it.
  • 750 Answers
Welcome ,
This means you have one or more relays that are defective.
Rather than spending your hard earned money randomly swapping out parts.
Call service and get it done in one shot and save money on parts. all that you spent on unnecessary parts could have went to a service call and a good meal this evening from your fine oven.
bless you,
huum
relays are the problem.
Please remember to leave a fine rating for our fine solution!
Posted on Dec 07, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
May 19, 2014 | Frigidaire GLEB30T8A Electric Double Oven
Frigidaire es300 bake element
The bake element
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 20, 2014 | Frigidaire Ovens
Was cooking I'n oven. Heard a big pop sound and saw lghtning I'n tne oven. Now oven will heat a little but won't cook or broil ?
That sounds like the heating element went out when it first goes it could look like a lightning strike. Replacing the bake or broil element ,depending which one was on at the time will fix your oven. If you were baking replace bake element if ya werebroiling replace that one.
Reply with EXACT model number and i'll give ya the part number
GENE
Aug 27, 2011 | Frigidaire Kitchen Ranges
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
Have a frigidaire oven, model# PLES389ECE. Broiler heating heats up but lower (bake) element does not. Element need replacing?
mos likely yes... but to confirm is very easy... unplug unit or turn circuit breaker off... in the oven with door open you will see the back of bake element where it goes into oven wall a couple of screws remove them and you should be able to gently pull element out...there are 2 terminals connected to element with a wire attached to each of them... first we are making sure the wire hasn't burnt off or cam edisconnected and second we can remove wires and use a volt meter and test power... set it up so you don't get electricuted and tuen oven on bake 350 do you have power coming to the wires with element diconnected from wires...if so then you have a bad element if not then a bad thermal cutooff usually located in back of unit ... good luck to you...
Jan 11, 2011 | Frigidaire Ovens
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF366 Electric Kitchen Range Logo
183 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
